Ana içeriğe geç
HP dv5-1125nr Disk Drive Replacement
Neye ihtiyacın var
  1. HP dv5-1125nr Disk Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr Disk Drive Replacement: adım 2, 1 resimden 1.
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
  3. HP dv5-1125nr Disk Drive Replacement, Disk Drive: adım 3, 2 resimden 1. HP dv5-1125nr Disk Drive Replacement, Disk Drive: adım 3, 2 resimden 2.
    • Locate two 3mm Phillips screws on the CMOS panel cover and remove them with a Phillips #00 screwdriver.
    • Remove the CMOS panel cover.
  4. HP dv5-1125nr Disk Drive Replacement: adım 4, 3 resimden 1. HP dv5-1125nr Disk Drive Replacement: adım 4, 3 resimden 2. HP dv5-1125nr Disk Drive Replacement: adım 4, 3 resimden 3.
    • The optical drive is now ready for removal. Using a plastic removal tool, lift the optical drive away from your computer.
    • Using your hands, slide the remainder of the drive out of the computer.
Sonuç
Nick Loey
1.688 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-15, Regan Spring 2014 Cal Poly, Team 9-15, Regan Spring 2014 üyesi
CPSU-REGAN-S14S9G15
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 733
