Ana içeriğe geç
Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
HP dv5-1125nr Hard Drive Replacement
Neye ihtiyacın var
  1. HP dv5-1125nr Hard Drive Replacement, Battery: adım 1, 1 resimden 1.
    • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
    • Slide the switch to the left until the release clicks.
  2. HP dv5-1125nr Hard Drive Replacement: adım 2, 1 resimden 1.
    • Remove the battery.
    • The release switch may need to be held down while removing the battery.
  3. HP dv5-1125nr Hard Drive Replacement, Hard Drive: adım 3, 2 resimden 1. HP dv5-1125nr Hard Drive Replacement, Hard Drive: adım 3, 2 resimden 2.
    • Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver.
  4. HP dv5-1125nr Hard Drive Replacement: adım 4, 1 resimden 1.
    • Remove the plastic hard drive cover.
  5. HP dv5-1125nr Hard Drive Replacement: adım 5, 2 resimden 1. HP dv5-1125nr Hard Drive Replacement: adım 5, 2 resimden 2.
    • Pull up on the two plastic flaps on the hard drive enclosure to remove it.
  6. HP dv5-1125nr Hard Drive Replacement: adım 6, 2 resimden 1. HP dv5-1125nr Hard Drive Replacement: adım 6, 2 resimden 2.
    • Gently lift the ribbon cable away from the hard drive enclosure to free the drive.
  7. HP dv5-1125nr Hard Drive Replacement: adım 7, 2 resimden 1. HP dv5-1125nr Hard Drive Replacement: adım 7, 2 resimden 2.
    • Locate four 2mm Phillips screws on the side of the enclosure and remove them using a Phillips #00 screwdriver.
    • Slide the hard drive out of the enclosure to complete the removal process.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Nick Loey
1.688 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-15, Regan Spring 2014 Cal Poly, Team 9-15, Regan Spring 2014 üyesi
CPSU-REGAN-S14S9G15
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 2,071
