Ana içeriğe geç
HP dv5-1125nr Keyboard Replacement
Neye ihtiyacın var
    1. HP dv5-1125nr Keyboard Replacement, Battery: adım 1, 1 resimden 1.
      • Ensure your computer is shut down. Removing the battery while the laptop is still on may corrupt your files. Remove any power adapters and cords connected to the laptop body.
      • Slide the switch to the left until the release clicks.
      FixBot'a Sor
      Yorum Ekle
    2. HP dv5-1125nr Keyboard Replacement: adım 2, 1 resimden 1.
      • Remove the battery.
      • The release switch may need to be held down while removing the battery.
      FixBot'a Sor
      Yorum Ekle
    1. HP dv5-1125nr Keyboard Replacement, Hard Drive: adım 3, 2 resimden 1. HP dv5-1125nr Keyboard Replacement, Hard Drive: adım 3, 2 resimden 2.
      • Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. HP dv5-1125nr Keyboard Replacement: adım 4, 1 resimden 1.
      • Remove the plastic hard drive cover.
      FixBot'a Sor
      Yorum Ekle
    3. HP dv5-1125nr Keyboard Replacement: adım 5, 2 resimden 1. HP dv5-1125nr Keyboard Replacement: adım 5, 2 resimden 2.
      • Pull up on the two plastic flaps on the hard drive enclosure to remove it.
      FixBot'a Sor
      Yorum Ekle
    4. HP dv5-1125nr Keyboard Replacement: adım 6, 2 resimden 1. HP dv5-1125nr Keyboard Replacement: adım 6, 2 resimden 2.
      • Gently lift the ribbon cable away from the hard drive enclosure to free the drive.
      FixBot'a Sor
      Yorum Ekle
    5. HP dv5-1125nr Keyboard Replacement: adım 7, 2 resimden 1. HP dv5-1125nr Keyboard Replacement: adım 7, 2 resimden 2.
      • Locate four 2mm Phillips screws on the side of the enclosure and remove them using a Phillips #00 screwdriver.
      • Slide the hard drive out of the enclosure to complete the removal process.
      FixBot'a Sor
      Yorum Ekle
    1. HP dv5-1125nr Keyboard Replacement, RAM: adım 8, 1 resimden 1.
      • Remove the one 4mm Phillips screw from the RAM cover using a Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. HP dv5-1125nr Keyboard Replacement: adım 9, 2 resimden 1. HP dv5-1125nr Keyboard Replacement: adım 9, 2 resimden 2.
      • Remove the RAM cover to reveal the module's underneath.
      FixBot'a Sor
      Yorum Ekle
    3. HP dv5-1125nr Keyboard Replacement: adım 10, 3 resimden 1. HP dv5-1125nr Keyboard Replacement: adım 10, 3 resimden 2. HP dv5-1125nr Keyboard Replacement: adım 10, 3 resimden 3.
      • Make sure to ground yourself before touching the RAM modules; they are very sensitive to static electricity.
      • Push the two metal tabs on the side of the RAM module outwards, towards the battery and CMOS compartments (up and down).
      • Once the module is released, gently pull the module upwards.
      • Repeat for the RAM module underneath the first one.
      FixBot'a Sor
      Yorum Ekle
    1. HP dv5-1125nr Keyboard Replacement, Keyboard: adım 11, 1 resimden 1.
      • Begin by unscrewing the three 3mm Phillips head screws inside the battery bay with the Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    2. HP dv5-1125nr Keyboard Replacement: adım 12, 1 resimden 1.
      • Remove the five remaining 2mm screws using a Phillips #00 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. HP dv5-1125nr Keyboard Replacement: adım 13, 1 resimden 1.
      • Unscrew the 4mm Phillips screw inside the hard drive bay.
      • Make sure to keep track of which screw goes where. The sizes are different for each set of screws!
      FixBot'a Sor
      Yorum Ekle
    4. HP dv5-1125nr Keyboard Replacement: adım 14, 2 resimden 1. HP dv5-1125nr Keyboard Replacement: adım 14, 2 resimden 2.
      • Locate the hole in between the hard drive and RAM compartments.
      • The hole is marked by a small keyboard symbol in the plastic (see the second picture).
      • Unscrew the 4mm Phillips head screw from this hole.
      FixBot'a Sor
      Yorum Ekle
    5. HP dv5-1125nr Keyboard Replacement: adım 15, 2 resimden 1. HP dv5-1125nr Keyboard Replacement: adım 15, 2 resimden 2.
      • Flip the laptop, and use the plastic opening tool on the side seam to remove the top cover.
      • You may need to use the opening tool on both sides of the cover.
      • Be careful not to break the ribbon cables under the cover.
      FixBot'a Sor
      Yorum Ekle
    6. HP dv5-1125nr Keyboard Replacement: adım 16, 1 resimden 1.
      Bu adımda kullanılan alet:
      Flathead 3/32" or 2.5 mm Screwdriver
      $5.49
      • Use a 2.5mm flathead screwdriver to remove the four 3mm screws on top of the keyboard.
      FixBot'a Sor
      Yorum Ekle
    7. HP dv5-1125nr Keyboard Replacement: adım 17, 1 resimden 1.
      • Dislodge the keyboard to access the underside.
      • Do not fully remove the keyboard. It is still attached by a ribbon cable, and forceful removal could break this necessary connection.
      FixBot'a Sor
      Yorum Ekle
    8. HP dv5-1125nr Keyboard Replacement: adım 18, 2 resimden 1. HP dv5-1125nr Keyboard Replacement: adım 18, 2 resimden 2.
      • Locate the ribbon cable connection between the keyboard and motherboard.
      • Pull upwards on the small black bar to release the ribbon cable and remove it.
      • Do not yank on the ribbon or try to pull it out. This may break the cable or motherboard.
      FixBot'a Sor
      Yorum Ekle
    9. HP dv5-1125nr Keyboard Replacement: adım 19, 1 resimden 1.
      • The keyboard is now ready for replacement.
      FixBot'a Sor
      Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. When reinserting the ribbon cable, it should click into place.
2 farklı kişi bu kılavuzu tamamladı.
Nick Loey
1.715 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 9-15, Regan Spring 2014 Cal Poly, Team 9-15, Regan Spring 2014 üyesi
CPSU-REGAN-S14S9G15
4 Üyeler
100 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 7
Son 30 gün: 27
Her zaman: 2,830
