Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
The dv5-1125nr keyboard is a single piece of plastic and is easy to replace when removed. New keyboards can be bought from HP or online. Unfortunately, it is one of the more difficult pieces to remove.
Neye ihtiyacın var
Remove the two 5mm Phillips screws on the hard drive cover using a Phillips #00 screwdriver.
Remove the one 4mm Phillips screw from the RAM cover using a Phillips #00 screwdriver.
Begin by unscrewing the three 3mm Phillips head screws inside the battery bay with the Phillips #00 screwdriver.
Use a 2.5mm flathead screwdriver to remove the four 3mm screws on top of the keyboard.
To reassemble your device, follow these instructions in reverse order. When reinserting the ribbon cable, it should click into place.
2 farklı kişi bu kılavuzu tamamladı.
