Ana içeriğe geç
HP dv7-4065x Keyboard Replacement
  1. HP dv7-4065x Keyboard Replacement, Keyboard: adım 1, 1 resimden 1.
    • Remove the battery from the laptop.
  2. HP dv7-4065x Keyboard Replacement: adım 2, 1 resimden 1.
    • Move the switch in the battery compartment.
  3. HP dv7-4065x Keyboard Replacement: adım 3, 1 resimden 1.
    • Carefully flip up the keyboard panel.
    • Don't pull far on the keyboard. It will still be connected to the laptop via ribbon cables.
  4. HP dv7-4065x Keyboard Replacement: adım 4, 1 resimden 1.
    • Lift the retaining flap on the keyboard cable ZIF connector.
    • Carefully pull the ribbon cable from its socket on the motherboard.
Sonuç
Mikayla Tabora
201 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team S3-G1, Botvin Spring 2017 UMass Dartmouth, Team S3-G1, Botvin Spring 2017 üyesi
UMASSD-BOTVIN-S17S3G1
3 Üyeler
4 adet Kılavuz yazıldı
Bir Yorum
First you need to unscrew 2 screws under the HDD cover
christo04 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 14
Her zaman: 1,619
