Ana içeriğe geç
HP eStation Zeen Ground Wire Replacement
Neye ihtiyacın var
  1. HP eStation Zeen Ground Wire Replacement, Motherboard Ground Wire: adım 1, 3 resimden 1. HP eStation Zeen Ground Wire Replacement, Motherboard Ground Wire: adım 1, 3 resimden 2. HP eStation Zeen Ground Wire Replacement, Motherboard Ground Wire: adım 1, 3 resimden 3.
    • Remove the screw caps using a metal spudger.
    • Remove the four 6 mm screws using a Phillips #0 screwdriver.
  2. HP eStation Zeen Ground Wire Replacement: adım 2, 3 resimden 1. HP eStation Zeen Ground Wire Replacement: adım 2, 3 resimden 2. HP eStation Zeen Ground Wire Replacement: adım 2, 3 resimden 3.
    • Insert a plastic opening tool into the case seam and slide it along the edges.
    • Lift and remove the back panel from the device.
  3. HP eStation Zeen Ground Wire Replacement: adım 3, 1 resimden 1.
    • Carefully disconnect the battery clip using small plastic spudger.
    • The clip is extremely fragile.
  4. HP eStation Zeen Ground Wire Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Use tweezers to disconnect the ground wire from motherboard terminal.
  5. HP eStation Zeen Ground Wire Replacement: adım 5, 1 resimden 1.
    • Use a soldering iron to remove the ground wire.
    • Avoid touching or heating the motherboard.
Sonuç
dalton hale
503 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-4, Eyestone Fall 2016 USF Tampa, Team 16-4, Eyestone Fall 2016 üyesi
USFT-EYESTONE-F16S16G4
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 8
Her zaman: 360
