Ana içeriğe geç
HP eStation Zeen Motherboard Replacement
Neye ihtiyacın var
  1. HP eStation Zeen Motherboard Replacement, Motherboard: adım 1, 3 resimden 1. HP eStation Zeen Motherboard Replacement, Motherboard: adım 1, 3 resimden 2. HP eStation Zeen Motherboard Replacement, Motherboard: adım 1, 3 resimden 3.
    • Remove the screw caps using the metal spudger.
    • Remove the four 6mm Phillips screws using the Phillips #0 screwdriver.
  2. HP eStation Zeen Motherboard Replacement: adım 2, 3 resimden 1. HP eStation Zeen Motherboard Replacement: adım 2, 3 resimden 2. HP eStation Zeen Motherboard Replacement: adım 2, 3 resimden 3.
    • Unclip each side of the back cover by inserting the plastic opening tool and sliding it along the edge.
    • Remove the back panel by lifting the panel away from the device.
  3. HP eStation Zeen Motherboard Replacement: adım 3, 1 resimden 1.
    • Disconnect battery clip with plastic opening tool.
    • The clip is very fragile.
  4. HP eStation Zeen Motherboard Replacement: adım 4, 1 resimden 1.
    • Disconnect the speaker terminal with the plastic opening tool.
  5. HP eStation Zeen Motherboard Replacement: adım 5, 1 resimden 1.
    • Disconnect the the volume button clip with metal spudger tool.
    • The clip is fragile.
  6. HP eStation Zeen Motherboard Replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Disconnect the ground wire from the motherboard with tweezers.
  7. HP eStation Zeen Motherboard Replacement: adım 7, 2 resimden 1. HP eStation Zeen Motherboard Replacement: adım 7, 2 resimden 2.
    • Remove the two 6mm Phillips screws with Phillips #0 screwdriver.
  8. HP eStation Zeen Motherboard Replacement: adım 8, 2 resimden 1. HP eStation Zeen Motherboard Replacement: adım 8, 2 resimden 2.
    • Pry off the clips that hold the motherboard down with the plastic spudger.
  9. HP eStation Zeen Motherboard Replacement: adım 9, 2 resimden 1. HP eStation Zeen Motherboard Replacement: adım 9, 2 resimden 2.
    • Lift motherboard up to expose the ribbons on the back.
    • Lift the grey tabs to disconnect the ribbons with plastic spudger.
Sonuç
Bir başkası bu kılavuzu tamamladı.
dalton hale
503 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-4, Eyestone Fall 2016 USF Tampa, Team 16-4, Eyestone Fall 2016 üyesi
USFT-EYESTONE-F16S16G4
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 575
