Giriş
Replacing the motherboard of the HP eStation Zeen is rated a difficult repair, however anyone with patients can do it. The largest challenges for making this repair is paying attention to details and using a light touch. There are screws to keep track of and multiple connections to unfasten and reconnect, but when taking the time to follow steps closely it is no more complex than replacing the 9 volt battery in most smoke detectors.
Neye ihtiyacın var
Remove the screw caps using the metal spudger.
Remove the four 6mm Phillips screws using the Phillips #0 screwdriver.
Bir başkası bu kılavuzu tamamladı.
