Ana içeriğe geç
HP eStation Zeen Speaker Replacement
Neye ihtiyacın var
  1. HP eStation Zeen Speaker Replacement, Speaker: adım 1, 3 resimden 1. HP eStation Zeen Speaker Replacement, Speaker: adım 1, 3 resimden 2. HP eStation Zeen Speaker Replacement, Speaker: adım 1, 3 resimden 3.
    • Remove the rubber screw caps using a metal spudger.
    • Remove the two 6mm screw using a Phillips #0 screwdriver.
  2. HP eStation Zeen Speaker Replacement: adım 2, 3 resimden 1. HP eStation Zeen Speaker Replacement: adım 2, 3 resimden 2. HP eStation Zeen Speaker Replacement: adım 2, 3 resimden 3.
    • Unclip each side by inserting the plastic opening tool and slide it along the edges.
    • Remove the back panel by lifting the panel away from the device.
  3. HP eStation Zeen Speaker Replacement: adım 3, 1 resimden 1.
    • Disconnect battery clip.
    • The clip is very fragile.
  4. HP eStation Zeen Speaker Replacement: adım 4, 1 resimden 1.
    • Disconnect the speaker wires from the terminal using a plastic opening tool.
    • Be careful the plastic connector is fragile
  5. HP eStation Zeen Speaker Replacement: adım 5, 1 resimden 1.
    • Remove the two 6mm screws using a Phillips #0 screwdriver.
Sonuç
Jack Clark
119 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 16-4, Eyestone Fall 2016 USF Tampa, Team 16-4, Eyestone Fall 2016 üyesi
USFT-EYESTONE-F16S16G4
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 192
