Ana içeriğe geç
HP eStation Zeen Volume Buttons Replacement
Neye ihtiyacın var
  1. HP eStation Zeen Volume Buttons Replacement, Volume Buttons: adım 1, 3 resimden 1. HP eStation Zeen Volume Buttons Replacement, Volume Buttons: adım 1, 3 resimden 2. HP eStation Zeen Volume Buttons Replacement, Volume Buttons: adım 1, 3 resimden 3.
    • Use a metal spudger to remove the four screw caps.
    • Remove the four 6 mm screws using a Philips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. HP eStation Zeen Volume Buttons Replacement: adım 2, 3 resimden 1. HP eStation Zeen Volume Buttons Replacement: adım 2, 3 resimden 2. HP eStation Zeen Volume Buttons Replacement: adım 2, 3 resimden 3.
    • Insert a plastic opening tool and slide it along the edge to open the back panel.
    • Lift the back panel away from the device.
    FixBot'a Sor
    Yorum Ekle
  3. HP eStation Zeen Volume Buttons Replacement: adım 3, 1 resimden 1.
    • Disconnect the battery clip with a plastic opening tool.
    • Be gentle as the connector is fragile.
    FixBot'a Sor
    Yorum Ekle
  4. HP eStation Zeen Volume Buttons Replacement: adım 4, 1 resimden 1.
    • Remove the two 6 mm screws using a Philips #0 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  5. HP eStation Zeen Volume Buttons Replacement: adım 5, 1 resimden 1.
    • Pull the ribbon from the board.
    • Be gentle as the ribbon is fragile.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
dalton hale
508 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-4, Eyestone Fall 2016 USF Tampa, Team 16-4, Eyestone Fall 2016 üyesi
USFT-EYESTONE-F16S16G4
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 31
Her zaman: 434
