Ana içeriğe geç
HP iPAQ H2200 faceplate replacement
Neye ihtiyacın var
  1. HP iPAQ H2200 faceplate replacement, Battery: adım 1, 1 resimden 1.
    • Press and slide the battery cover tab to remove battery cover.
  2. HP iPAQ H2200 faceplate replacement: adım 2, 2 resimden 1. HP iPAQ H2200 faceplate replacement: adım 2, 2 resimden 2.
    • Pull on the black tab to lift the battery out of the battery compartment.
  3. HP iPAQ H2200 faceplate replacement, Main Board: adım 3, 1 resimden 1.
    • Remove the stylus by sliding it out of the slot.
  4. HP iPAQ H2200 faceplate replacement: adım 4, 1 resimden 1.
    • Remove the CF card by sliding it out of the slot at the top of the device.
  5. HP iPAQ H2200 faceplate replacement: adım 5, 1 resimden 1.
    • Press down and push the black side strips toward the top of the device to remove them.
  6. HP iPAQ H2200 faceplate replacement: adım 6, 3 resimden 1. HP iPAQ H2200 faceplate replacement: adım 6, 3 resimden 2. HP iPAQ H2200 faceplate replacement: adım 6, 3 resimden 3.
    • Using the T5 Torx screwdriver, remove all six screws on the back and all screws on each side of the device.
  7. HP iPAQ H2200 faceplate replacement: adım 7, 2 resimden 1. HP iPAQ H2200 faceplate replacement: adım 7, 2 resimden 2.
    • Remove the back faceplate by pushing and loosening the 4 side slots (2 on each side).
  8. HP iPAQ H2200 faceplate replacement: adım 8, 1 resimden 1.
    • Open the LCD connector, where the orange strip attaches to the main board.
  9. HP iPAQ H2200 faceplate replacement: adım 9, 1 resimden 1.
    • Carefully remove the orange LCD strip from the connector.
  10. HP iPAQ H2200 faceplate replacement: adım 10, 1 resimden 1.
    • Unscrew the 2 screws located at each top corner of the main board.
  11. HP iPAQ H2200 faceplate replacement: adım 11, 1 resimden 1.
    • Remove the main board by pushing outward on the two tabs located on each side near the bottom of the device.
  12. HP iPAQ H2200 faceplate replacement, LCD Screen: adım 12, 1 resimden 1.
    • Unscrew the two bottom screws on LCD screen that were previously located under the main board.
  13. HP iPAQ H2200 faceplate replacement: adım 13, 2 resimden 1. HP iPAQ H2200 faceplate replacement: adım 13, 2 resimden 2.
    • Press on side tabs to loosen and remove the LCD screen.
  14. HP iPAQ H2200 faceplate replacement, Faceplates: adım 14, 1 resimden 1.
    • Remove the faceplate by unscrewing the green screw located on the top right of the front faceplate.
Sonuç
Tyler Andrews
209 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-12, Forte Winter 2010 Cal Poly, Team 4-12, Forte Winter 2010 üyesi
CPSU-FORTE-W10S4G12
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 1,519
