Ana içeriğe geç
HP iPAQ h4155 LCD screen replacement
Neye ihtiyacın var
  1. HP iPAQ h4155 LCD screen replacement, Battery: adım 1, 1 resimden 1.
    • While sliding the silver release tab up, simultaneously lift the cover up from the left side.
  2. HP iPAQ h4155 LCD screen replacement: adım 2, 1 resimden 1.
    • Push the tab left to right to remove the cover.
  3. HP iPAQ h4155 LCD screen replacement: adım 3, 1 resimden 1.
    • Now, lift the battery up and away from the device to remove it.
  4. HP iPAQ h4155 LCD screen replacement, Back Case: adım 4, 1 resimden 1.
    • Remove the four silver screws using the T5 Torx Screwdriver (T5 x .25 in).
  5. HP iPAQ h4155 LCD screen replacement: adım 5, 1 resimden 1.
    • Remove the single black screw that is located beneath the HP sticker with the T5 Torx Screwdriver.
  6. HP iPAQ h4155 LCD screen replacement: adım 6, 2 resimden 1. HP iPAQ h4155 LCD screen replacement: adım 6, 2 resimden 2.
    • Next, use your plastic removal tool to separate the gray back from the black center piece.
    • For better results, start the separation at the corner piece.
  7. HP iPAQ h4155 LCD screen replacement: adım 7, 1 resimden 1.
    • Remove the back case.
  8. HP iPAQ h4155 LCD screen replacement, Face Plate: adım 8, 1 resimden 1.
    • Now that the back cover is removed, use the #00 Philips x .17 screwdriver to remove the small screw to the left of the SD card slot.
  9. HP iPAQ h4155 LCD screen replacement: adım 9, 2 resimden 1. HP iPAQ h4155 LCD screen replacement: adım 9, 2 resimden 2.
    • Next, unlock and remove the ribbon cable.
    • Using metal tweezers, carefully pull back on both sides of the brown bar unlocking the cable and slipping it out of the connector.
    • The bar, the connector, and the cable are fragile components that are easily broken.
  10. HP iPAQ h4155 LCD screen replacement: adım 10, 2 resimden 1. HP iPAQ h4155 LCD screen replacement: adım 10, 2 resimden 2.
    • Next, remove the wire from the bottom of the mother board.
    • The easiest method is to use metal tweezers and grip the plug closest to the connector.
    • Make sure all the connections are properly disconnected before separation from the motherboard.
  11. HP iPAQ h4155 LCD screen replacement: adım 11, 1 resimden 1.
    • Next, use a plastic removal tool and separate the silver front case from the black frame.
  12. HP iPAQ h4155 LCD screen replacement, Touch LCD Screen: adım 12, 2 resimden 1. HP iPAQ h4155 LCD screen replacement, Touch LCD Screen: adım 12, 2 resimden 2.
    • Now that the front cover is removed we can detach the screen
    • Remove the ribbon connector by pulling gently on the silver top. It will snap off the mother board.
    • The ribbon cable and connector can be easily removed if you genetly lift up the motherboard to create a small gap
  13. HP iPAQ h4155 LCD screen replacement: adım 13, 3 resimden 1. HP iPAQ h4155 LCD screen replacement: adım 13, 3 resimden 2. HP iPAQ h4155 LCD screen replacement: adım 13, 3 resimden 3.
    • Now the screen can be removed
Sonuç
Bir başkası bu kılavuzu tamamladı.
John Pagliero
942 İtibar
7 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 7
Her zaman: 1,530
