Ana içeriğe geç
HP rp5700 Cover Removal Replacement
  1. HP rp5700 Cover Removal Replacement, Cover Removal: adım 1, 1 resimden 1.
    • Make sure the computer is unplugged.
    • Be sure to touch any metal surface with your hand to discharge any static electricity that might have built up.
    • Make sure all auxiliary cords are disconnected from the desktop. If not, remove them using your hands.
    • Set the desktop down horizontally with the front side facing you.
  2. HP rp5700 Cover Removal Replacement: adım 2, 2 resimden 1. HP rp5700 Cover Removal Replacement: adım 2, 2 resimden 2.
    • Hold the desktop with two hands by grasping both sides of the desktop.
    • Press the buttons on both sides using your index fingers.
  3. HP rp5700 Cover Removal Replacement: adım 3, 3 resimden 1. HP rp5700 Cover Removal Replacement: adım 3, 3 resimden 2. HP rp5700 Cover Removal Replacement: adım 3, 3 resimden 3.
    • Slide the top cover about an inch forward using your thumb to push it towards you.
    • Make sure that the bottom is still secured by both hands.
    • Lay the desktop back on the table and pull the case forward as far as it can go.
    • Lift the cover up and off.
Sonuç
11 farklı kişi bu kılavuzu tamamladı.
Alyssa Briones
1.699 İtibar
9 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-23, Maness Winter 2014 Cal Poly, Team 6-23, Maness Winter 2014 üyesi
CPSU-MANESS-W14S6G23
4 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 12
Son 30 gün: 78
Her zaman: 21,533
