Ana içeriğe geç
Giriş
The hard drive is the component that provides information storage for the computer. Use caution when handling the hard drive. Any type of shock to the drive could cause hard drive failure.
  1. HP rp5700 Hard Drive Replacement, Cover Removal: adım 1, 1 resimden 1.
    • Make sure the computer is unplugged.
    • Be sure to touch any metal surface with your hand to discharge any static electricity that might have built up.
    • Make sure all auxiliary cords are disconnected from the desktop. If not, remove them using your hands.
    • Set the desktop down horizontally with the front side facing you.
  2. HP rp5700 Hard Drive Replacement: adım 2, 2 resimden 1. HP rp5700 Hard Drive Replacement: adım 2, 2 resimden 2.
    • Hold the desktop with two hands by grasping both sides of the desktop.
    • Press the buttons on both sides using your index fingers.
  3. HP rp5700 Hard Drive Replacement: adım 3, 3 resimden 1. HP rp5700 Hard Drive Replacement: adım 3, 3 resimden 2. HP rp5700 Hard Drive Replacement: adım 3, 3 resimden 3.
    • Slide the top cover about an inch forward using your thumb to push it towards you.
    • Make sure that the bottom is still secured by both hands.
    • Lay the desktop back on the table and pull the case forward as far as it can go.
    • Lift the cover up and off.
  4. HP rp5700 Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 1. HP rp5700 Hard Drive Replacement, Hard Drive: adım 4, 2 resimden 2.
    • Using your right hand, grip the CD drive and lift it up to a 90 degree position.
  5. HP rp5700 Hard Drive Replacement: adım 5, 2 resimden 1. HP rp5700 Hard Drive Replacement: adım 5, 2 resimden 2.
    • Use your hand, whichever you prefer, to grip the two cords on the CD drive and remove the two cords by pulling up.
    • Repeat the same process to remove the two cords connected to the Hard Drive.
  6. HP rp5700 Hard Drive Replacement: adım 6, 1 resimden 1.
    • Use your right index finger to pull forward the green flap on the side of the hard drive.
    • At the same time as you are lifting the green flap, use your left hand to lift the hard drive up and out.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Alyssa Briones
1.660 İtibar
9 adet Kılavuz yazıldı
Cal Poly, Team 6-23, Maness Winter 2014 Cal Poly, Team 6-23, Maness Winter 2014 üyesi
CPSU-MANESS-W14S6G23
4 Üyeler
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 10
Son 30 gün: 68
Her zaman: 3,022
