Giriş
The power supply functions exactly as it sounds, it supplies power to the computer. Some components inside the computer need a direct connection to the power supply whereas others may draw power directly through their connection to the motherboard. Many power supply will have power cables that hang loss inside the case. These loss cables are there in case there are new components added to the computer that need them.
Make sure the computer is unplugged.
Make sure all auxiliary cords are disconnected from the desktop. If not, remove them using your hands.
Set the desktop down horizontally with the front side facing you.
Slide the top cover about an inch forward using your thumb to push it towards you.
Make sure that the bottom is still secured by both hands.
Lay the desktop back on the table and pull the case forward as far as it can go.
Lift the cover up and off.
Using your hand, grip the Optical Drive and lift it up into a 45 degree angle.
Using your right index finger, press the tab with the green sticker located underneath the power supply.
While pressing the tab, lift up the power supply the same way you lifted up the optical drive.
Remove the two cables on the motherboard by grasping the cables with your hand and pulling the cables up and out.
Repeat the same process to remove the internal card power cable.
This is the same process as preformed when you previously removed the power cables from the optical drive and the hard drive.
Some cables may have small clips securing them in place. If so, be sure to press these clips inward using your fingers before pulling them out.
5 farklı kişi bu kılavuzu tamamladı.
