Ana içeriğe geç
HP w2216h Control Buttons Replacement
Neye ihtiyacın var
    1. HP w2216h Control Buttons Replacement, Control Buttons: adım 1, 1 resimden 1.
      • Make sure you are grounded, the power supply is not connected, and you are wearing safety goggles.
      • Remove the four 12 mm Phillips #000 screws on the back panel.
      FixBot'a Sor
      Yorum Ekle
    2. HP w2216h Control Buttons Replacement: adım 2, 2 resimden 1. HP w2216h Control Buttons Replacement: adım 2, 2 resimden 2.
      • Remove the two 12 mm Phillips #000 screws above stand mounting bracket.
      • Using a Phillips #1 with the 150 mm flexible extension remove 1 Phillips #1 screw under the stand mounting bracket.
      • Stand will easily pull off.
      FixBot'a Sor
      Yorum Ekle
    3. HP w2216h Control Buttons Replacement: adım 3, 3 resimden 1. HP w2216h Control Buttons Replacement: adım 3, 3 resimden 2. HP w2216h Control Buttons Replacement: adım 3, 3 resimden 3.
      • Do not put the metal spudger between the metal and the glass. It needs to go under the bezel and above the metal.
      • Turn monitor so that the screen is facing you.
      • Pry the black bezel from above the metal by placing your metal spudger between the bezel and the metal and twisting the tool slightly.
      • The best places to pry are in the lower left and lower right corners of the black bezel.
      FixBot'a Sor
      Yorum Ekle
    4. HP w2216h Control Buttons Replacement: adım 4, 1 resimden 1.
      • Lift the screen assembly from the plastic housing from the corners.
      FixBot'a Sor
      Yorum Ekle
    5. HP w2216h Control Buttons Replacement: adım 5, 1 resimden 1.
      • Remove the plastic buttons from the contacts
      FixBot'a Sor
      Yorum Ekle
    6. HP w2216h Control Buttons Replacement: adım 6, 2 resimden 1. HP w2216h Control Buttons Replacement: adım 6, 2 resimden 2.
      • Remove the wire connecting the contacts to the screen assembly.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Patrick Aucoin
221 İtibar
2 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-1, Miles Spring 2016 UMass Dartmouth, Team 1-1, Miles Spring 2016 üyesi
UMASSD-MILES-S16S1G1
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 35
Her zaman: 833
