Ana içeriğe geç
Giriş
If the CPU fan becomes to filled with dust or stops spinning, it must be replaced immediately. If it is not replaced then the CPU or motherboard can become damaged and cause the computer to be unbootable
Aletler
Parçalar
  1. Lay the tower down carefully on its right side, with the vents pointing up. Lay the tower down carefully on its right side, with the vents pointing up.
    • Lay the tower down carefully on its right side, with the vents pointing up.
  2. iPhone Pil Tamir Setleri
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  3. Use the flat head #6 screwdriver bit to unscrew the tower casing. Very gently slide the case towards you. Lift the casing up and gently place it off to the side.
    • Use the flat head #6 screwdriver bit to unscrew the tower casing.
    • Very gently slide the case towards you.
    • Lift the casing up and gently place it off to the side.
  4. Unplug the fan from the motherboard by gently grasping the connector and slowing pulling up. Remove each screw from the fan using the Phillips head screwdriver bit. Place the screws in a cup, they are very small and can be lost easily.
    • Unplug the fan from the motherboard by gently grasping the connector and slowing pulling up.
    • Remove each screw from the fan using the Phillips head screwdriver bit.
    • Place the screws in a cup, they are very small and can be lost easily.
    • Remove the old fan from the CPU.
Sonuç
To reassemble your device, follow these instructions in reverse order. Now you should feel confident replacing the CPU fan in your HP desktop without any difficulties.
Amanda Milby
117 İtibar
1 Kılavuz yazıldı
Takım
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 3
Son 30 Gün: 8
Her zaman: 111
