Giriş
https://www.youtube.com/watch?v=4rojpK1Y...
It is not easy to disassemble the HTC 10. The inner design of HTC 10 is complicated.
Neye ihtiyacın var
Video talimatları
Neredeyse bitti!
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
7 Yorum
Be VERY careful around the corners of the screen when removing the display. The LCD can be damaged easily if the card (or any other adhesive removing tool) is pushed too far. As you can see in this video as he pushes the card near the bottom right corner of the display, he is also messing with the LCD.
Joona Repo - Yanıt
Hello,
Can you tell me which is the total track lenght of the rear camera? It seems to be shorter than the front camera, isn’t it?
Thank you Ivan
Ivan Perino - Yanıt
at 5:14 part, what is the wire connected to? what if it breaks?
OTrizy - Yanıt
Hey can you tell me where is the emmc chip ? Regards
Dekaj Armand - Yanıt
Where is the antenna for wifi and bluetooth? After battary replacement my wifi and bluetooth stoped working.
Çağdaş Son - Yanıt
Where I find the NFC CHIP and the GPS Antenna?
Leon Menezes - Yanıt
Overall easy enough to follow but with speeded up sequences there's quite a bit of rewinding to properly view some steps. One point to note is that the video does not mention removal of the sim or sd card readers, this isn't easy from an existing mid frame bezel. May be easier to source replacements to fit into a new bezel,
Brendon Gould - Yanıt
