Giriş
HTC Desire 510 / RIO - How to replace broken, not working Digitizer glass and/or LCD Display.
Neye ihtiyacın var
Videoya Genel Bakış
Switch off the phone, remove the battery and any installed SIM and memory cards.
Remove 7x Torx T5 screws.
Use a plastic tool to remove the rear bezel.
The loudspeaker is on the inner side of the rear bezel.
Disconnect the touch screen flex cable.
Disconnect the light sensor flex cable.
Unstuck the vibra-motor from the middle frame.
Remove the coaxial antenna cable from the middle frame.
At the upper left side, the board is held by a plastic locking clip. Use a plastic tool and start the separating from here.
Gently disconnect the LCD display flex cable.
Now remove the logic board.
Put a scotch tape to prevent the glass from scattering.
Use a hot gun or hair dryer and warm the glass. This will make the adhesive soften and the separation easier.
Use a cutter and slightly lift the glass in one of the corners. When you make enough room, put a plastic tool.
Continue the separating with plastic tools to prevent the middle frame from scratches.
The digitizer flex cable goes under the LCD display.
Slightly lift the display and unstuck the digitizer ribbon cable from the from the rear side of the display.
If you have a broken LCD display, use a plastic tool and remove it from the middle frame.
It's not glued to the frame.
Install a new adhesive tape on the digitizer glass.
First put the touch screen flex cable in the right hole and then install the LCD Display.
Now is time to reassemble the phone.
That's all.
Did you do it successfully?
10 farklı kişi bu kılavuzu tamamladı.
3 Yorum
I did exactly this and when I turn on my phone, the digitizer recognizes touches for a few milliseconds (buggy touches) when I touch it then it stops recognizing touches. What did I do wrong?
hello i want to buy HTC desire 510 Screen because my htc mobile Touch is not working. i want to buy. plz tell me to am i buy .
