Ana içeriğe geç
HTC Desire 530 Battery Replacement
Neye ihtiyacın var
  1. HTC Desire 530 Battery Replacement, Battery: adım 1, 2 resimden 1. HTC Desire 530 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Use the plastic opening tools to remove the plastic speaker covers that are attached through an adhesive layer.
    • They may be difficult to peel off and you might want to consider loosening the adhesive layer by running a hair dryer or a heat gun over it briefly to allow them to peel off easily.
  2. HTC Desire 530 Battery Replacement: adım 2, 3 resimden 1. HTC Desire 530 Battery Replacement: adım 2, 3 resimden 2. HTC Desire 530 Battery Replacement: adım 2, 3 resimden 3.
    • Use the T5 Torx screwdriver to remove the four screws in each corner.
    • Make sure to take out any SD cards, located on the left side of the phone before proceeding to the next step.
    • Use the plastic opening tool to pry the front of the device off. Fully go around the front with the plastic opening tool before attempting to pull it off.
  3. HTC Desire 530 Battery Replacement: adım 3, 3 resimden 1. HTC Desire 530 Battery Replacement: adım 3, 3 resimden 2. HTC Desire 530 Battery Replacement: adım 3, 3 resimden 3.
    • Dislocate the small piece with the wires connected using a nylon spudger.
    • Loosen the adhesive layer for the battery by running a hair dryer over it briefly. After the adhesive is loosened you can pry the battery out with a plastic opening tool.
  4. HTC Desire 530 Battery Replacement: adım 4, 2 resimden 1. HTC Desire 530 Battery Replacement: adım 4, 2 resimden 2.
    • After prying, simply lift the battery up and out of the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Alyssa
205 İtibar
1 Kılavuz yazıldı
Ekip
UMASSD-PEAK-F18S3G2 UMASSD-PEAK-F18S3G2 üyesi
Community
3 Üyeler
10 adet Kılavuz yazıldı
2 Yorum
Mi phone is sealed no scrows on my phone HTC Desire 530 so haw can i get the Battery out
robert jelley - Yanıt
My phone is sealed so awe can i get the Battery out it is HTC desire 530
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 4,181
