Ana içeriğe geç
HTC Desire 610 Charging Port Replacement
Neye ihtiyacın var
  1. HTC Desire 610 Charging Port Replacement, Black Plastic Circuit Cover: adım 1, 3 resimden 1. HTC Desire 610 Charging Port Replacement, Black Plastic Circuit Cover: adım 1, 3 resimden 2. HTC Desire 610 Charging Port Replacement, Black Plastic Circuit Cover: adım 1, 3 resimden 3.
    • Using a plastic opening tool, take off the back cover of the phone.
  2. HTC Desire 610 Charging Port Replacement: adım 2, 1 resimden 1.
    • Remove the four black 4mm torx screws using the Torx T5 bit.
  3. HTC Desire 610 Charging Port Replacement: adım 3, 1 resimden 1.
    • Remove the four silver 5mm torx head screws using the Torx T5 screwdriver.
  4. HTC Desire 610 Charging Port Replacement: adım 4, 1 resimden 1.
    • Remove the two 2.5mm phillips head screws using the Phillips 000 screwdriver.
  5. HTC Desire 610 Charging Port Replacement: adım 5, 1 resimden 1.
    • Remove the black plastic circuit cover using a plastic opening tool.
  6. HTC Desire 610 Charging Port Replacement, Charging Port: adım 6, 1 resimden 1.
    • Remove the 4mm black Torx screw using a Torx T5 screwdriver.
  7. HTC Desire 610 Charging Port Replacement: adım 7, 1 resimden 1.
    • Using a pair of tweezers, disconnect the antenna wire.
  8. HTC Desire 610 Charging Port Replacement: adım 8, 3 resimden 1. HTC Desire 610 Charging Port Replacement: adım 8, 3 resimden 2. HTC Desire 610 Charging Port Replacement: adım 8, 3 resimden 3.
    • Peel back the gray adhesive strip using the precision tweezers.
  9. HTC Desire 610 Charging Port Replacement: adım 9, 1 resimden 1.
    • Pull up on the white strip so it sits 90 degrees using a pair of precision tweezers.
  10. HTC Desire 610 Charging Port Replacement: adım 10, 3 resimden 1. HTC Desire 610 Charging Port Replacement: adım 10, 3 resimden 2. HTC Desire 610 Charging Port Replacement: adım 10, 3 resimden 3.
    • Pry up the circuit board and pull it out using a pair of precision tweezers.
  11. HTC Desire 610 Charging Port Replacement: adım 11, 3 resimden 1. HTC Desire 610 Charging Port Replacement: adım 11, 3 resimden 2. HTC Desire 610 Charging Port Replacement: adım 11, 3 resimden 3.
    • Remove the loud speaker using a pair of precision tweezers.
    • The loud speaker is attached with adhesive and may require more force than expected to remove.
    • The prongs on the speaker should be sticking up towards the top of the phone when you put the speaker on the new circuit board.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Kaycee Hammond
273 İtibar
2 adet Kılavuz yazıldı
Ekip
IUPUI, Team S1-G1, Wilson Spring 2017 IUPUI, Team S1-G1, Wilson Spring 2017 üyesi
IUPUI-WILSON-S17S1G1
4 Üyeler
6 adet Kılavuz yazıldı
Bir Yorum
Super duper 5
Nizamcdk - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 1,218
