Ana içeriğe geç
HTC Desire 610 Daughterboard Replacement
Neye ihtiyacın var
  1. HTC Desire 610 Daughterboard Replacement, Daughterboard: adım 1, 1 resimden 1.
    • Open the SD card slot.
  2. HTC Desire 610 Daughterboard Replacement: adım 2, 3 resimden 1. HTC Desire 610 Daughterboard Replacement: adım 2, 3 resimden 2. HTC Desire 610 Daughterboard Replacement: adım 2, 3 resimden 3.
    • Using plastic opening tool, take off the back cover of the phone.
  3. HTC Desire 610 Daughterboard Replacement: adım 3, 1 resimden 1.
    • Using Phillips #000 Screwdriver, remove the two 2.5mm phillips head screws.
  4. HTC Desire 610 Daughterboard Replacement: adım 4, 1 resimden 1.
    • Using Torx T5 Screwdriver, remove the four 5mm silver torx head screws.
  5. HTC Desire 610 Daughterboard Replacement: adım 5, 1 resimden 1.
    • Using Torx T5 Screwdriver, remove the four 4mm black torx screws
  6. HTC Desire 610 Daughterboard Replacement: adım 6, 2 resimden 1. HTC Desire 610 Daughterboard Replacement: adım 6, 2 resimden 2.
    • Using plastic opening tool, remove the black plastic circuit cover.
  7. HTC Desire 610 Daughterboard Replacement: adım 7, 1 resimden 1.
    • Using Torx T5 Screwdriver, remove the 4mm black torx screw.
  8. HTC Desire 610 Daughterboard Replacement: adım 8, 2 resimden 1. HTC Desire 610 Daughterboard Replacement: adım 8, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Using Tweezers, disconnect antenna wire.
  9. HTC Desire 610 Daughterboard Replacement: adım 9, 3 resimden 1. HTC Desire 610 Daughterboard Replacement: adım 9, 3 resimden 2. HTC Desire 610 Daughterboard Replacement: adım 9, 3 resimden 3.
    • Using Tweezers, remove loud speaker that is being held by small adhesive.
    • When putting loud speaker back on, the prongs sticking up should be on the side closer to the top of the phone.
  10. HTC Desire 610 Daughterboard Replacement: adım 10, 2 resimden 1. HTC Desire 610 Daughterboard Replacement: adım 10, 2 resimden 2.
    • Using Tweezers, peel back gray adhesive.
  11. HTC Desire 610 Daughterboard Replacement: adım 11, 2 resimden 1. HTC Desire 610 Daughterboard Replacement: adım 11, 2 resimden 2.
    • Using Tweezers, flip the white strip upward so it sits 90°.
  12. HTC Desire 610 Daughterboard Replacement: adım 12, 3 resimden 1. HTC Desire 610 Daughterboard Replacement: adım 12, 3 resimden 2. HTC Desire 610 Daughterboard Replacement: adım 12, 3 resimden 3.
    • Using plastic opening tool, pry up green plate and pull outward.
    • Daughterboard is off. Get new daughterboard and reverse steps.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 1,665
