Ana içeriğe geç
HTC Desire 626 Battery Replacement
Neye ihtiyacın var
  1. HTC Desire 626 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Insert an opening pick between the back cover and chassis, and pry around the perimeter until the back cover releases.
    • Remove the back cover.
  2. HTC Desire 626 Battery Replacement: adım 2, 2 resimden 1. HTC Desire 626 Battery Replacement: adım 2, 2 resimden 2.
    • Remove the "void" sticker over the screw near the top-right of the battery, and the larger one near bottom of the battery.
    • Don't worry about voiding warranties; those stickers are illegal in the US!
    • Use a Torx T5 screwdriver to remove the six screws.
    • Use a Phillips #000 screwdriver to remove the two screws.
  3. HTC Desire 626 Battery Replacement: adım 3, 1 resimden 1.
    • Remove the white plastic frame with the opening tool.
  4. HTC Desire 626 Battery Replacement: adım 4, 2 resimden 1. HTC Desire 626 Battery Replacement: adım 4, 2 resimden 2.
    • Use an ESD safe tool to carefully "walk" the battery connector out of its port.
    • Use an opening tool to lift the battery up and out of its housing.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 20
Her zaman: 436
