Giriş
This is a device removal guide for your HTC Desire 626s auxiliary port (headphone jack) if ever in need of replacement.
Neye ihtiyacın var
Insert plastic opening tool in between the back cover and grey plastic.
Gently work your way around the phone while sliding the tool.
Gently pry on plastic cover as needed to release fasteners.
Once the screws are removed, use the plastic opening tool to remove the remaining plastic cover.
Start from the corners of the phone, and insert the plastic opening tool between the outer colored rim and the screen.
This portion of the cover will be more difficult to remove than the initial back cover. Be patient and gentle around the button holes.
Look for the clear piece of tape covering the wires connecting the aux port to the phone.
Use the tweezers to remove this tape and stick it to the large metal plate on the phone for safe keeping.
