Ana içeriğe geç
HTC Desire 626s Backplate Replacement
Neye ihtiyacın var
  1. HTC Desire 626s Backplate Replacement, Backplate: adım 1, 3 resimden 1. HTC Desire 626s Backplate Replacement, Backplate: adım 1, 3 resimden 2. HTC Desire 626s Backplate Replacement, Backplate: adım 1, 3 resimden 3.
    • Insert plastic opening tool in between the back cover and grey plastic.
    • Gently work your way around the phone while sliding the tool.
    • Gently pry on plastic cover as needed to release fasteners.
  2. HTC Desire 626s Backplate Replacement: adım 2, 2 resimden 1. HTC Desire 626s Backplate Replacement: adım 2, 2 resimden 2.
    • There are 7 screws you need to remove before prying the secondary cover off. You will need to use the JIS #000 screwdriver and the T5 Torx screwdriver to remove these screws.
    • There is a screw under the "void" sticker.
  3. HTC Desire 626s Backplate Replacement: adım 3, 2 resimden 1. HTC Desire 626s Backplate Replacement: adım 3, 2 resimden 2.
    • Once the screws are removed, use the plastic opening tool to remove the remaining plastic cover.
    • Start from the corners of the phone, and insert the plastic opening tool between the outer colored rim and the screen.
    • This portion of the cover will be more difficult to remove than the initial back cover. Be patient and gentle around the button holes.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 276
