Ana içeriğe geç
HTC Desire 626s Battery Replacement
Neye ihtiyacın var
  1. HTC Desire 626s Battery Replacement, Backplate: adım 1, 3 resimden 1. HTC Desire 626s Battery Replacement, Backplate: adım 1, 3 resimden 2. HTC Desire 626s Battery Replacement, Backplate: adım 1, 3 resimden 3.
    • Insert plastic opening tool in between the back cover and grey plastic.
    • Gently work your way around the phone while sliding the tool.
    • Gently pry on plastic cover as needed to release fasteners.
  2. HTC Desire 626s Battery Replacement: adım 2, 2 resimden 1. HTC Desire 626s Battery Replacement: adım 2, 2 resimden 2.
    • There are 7 screws you need to remove before prying the secondary cover off. You will need to use the JIS #000 screwdriver and the T5 Torx screwdriver to remove these screws.
    • There is a screw under the "void" sticker.
  3. HTC Desire 626s Battery Replacement: adım 3, 2 resimden 1. HTC Desire 626s Battery Replacement: adım 3, 2 resimden 2.
    • Once the screws are removed, use the plastic opening tool to remove the remaining plastic cover.
    • Start from the corners of the phone, and insert the plastic opening tool between the outer colored rim and the screen.
    • This portion of the cover will be more difficult to remove than the initial back cover. Be patient and gentle around the button holes.
  4. HTC Desire 626s Battery Replacement, Battery: adım 4, 1 resimden 1.
    • By using the angled tweezers, you have to be careful when you try to remove the battery connection by start pulling the wires.
  5. HTC Desire 626s Battery Replacement: adım 5, 1 resimden 1.
    • Using the plastic opening tool to separate the battery and remove it.
  6. HTC Desire 626s Battery Replacement: adım 6, 1 resimden 1.
    • Pull the battery out
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 14
Her zaman: 2,051
