Ana içeriğe geç
HTC Desire 700 Dual Sim Front Facing Camera Replacement
Neye ihtiyacın var
  1. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Back Cover: adım 1, 1 resimden 1.
    • Use the spudger to pry the back cover off.
    FixBot'a Sor
    Yorum Ekle
  2. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Removing Battery: adım 2, 1 resimden 1.
    • Use spudger tool to pry under the battery to lift it up and out.
    FixBot'a Sor
    Yorum Ekle
  3. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Remove 8 Torx Screws: adım 3, 1 resimden 1.
    • Remove eight 8.3mm T4 screws with the Torx screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Prying Off Rear Panel: adım 4, 1 resimden 1.
    • Pry the back panel of the screen using the plastic opener.
    • Work your way gently around the device, using picks as necessary to keep the back panel separated.
    • Use caution not to damage the device, as it takes force to remove the rear panel.
    FixBot'a Sor
    Yorum Ekle
  5. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Motherboard: adım 5, 1 resimden 1.
    • Remove the 3mm PH00 screw located at the bottom center of the motherboard using a P#00 Phillip's head screwdriver.
    FixBot'a Sor
    Yorum Ekle
  6. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Disconnect Vibrator Wire: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Using the tweezers gently disconnect the wire from the vibrator located on the motherboard.
    FixBot'a Sor
    Yorum Ekle
  7. HTC Desire 700 Dual Sim Front Facing Camera Replacement: adım 7, 1 resimden 1.
    • Remove volume control button ribbon with tweezers.
    FixBot'a Sor
    Yorum Ekle
  8. HTC Desire 700 Dual Sim Front Facing Camera Replacement: adım 8, 1 resimden 1.
    • Carefully remove the ribbon attached to the top of the motherboard.
    FixBot'a Sor
    Yorum Ekle
  9. HTC Desire 700 Dual Sim Front Facing Camera Replacement: adım 9, 1 resimden 1.
    • Unsnap the wire from the printed circuit board (PCB) using the tweezers.
    FixBot'a Sor
    Yorum Ekle
  10. HTC Desire 700 Dual Sim Front Facing Camera Replacement, Removing Camera: adım 10, 1 resimden 1.
    • Remove the camera using the plastic opening tool as shown.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Steven Pate
196 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-3, Blackwell Fall 2014 USF Tampa, Team 9-3, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S9G3
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 31
Her zaman: 1,089
