Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Use spudger tool to pry under the battery to lift it up and out.
Remove eight 8.3mm T4 screws with the Torx screwdriver.
Pry the back panel of the screen using the plastic opener.
Work your way gently around the device, using picks as necessary to keep the back panel separated.
Remove the 3mm PH00 screw located at the bottom center of the motherboard using a P#00 Phillip's head screwdriver.
Using the tweezers gently disconnect the wire from the vibrator located on the motherboard.
Carefully remove the ribbon attached to the top of the motherboard.
Unsnap the wire from the printed circuit board (PCB) using the tweezers.
Remove the camera using the plastic opening tool as shown.
