Ana içeriğe geç
HTC Desire 700 Dual Sim Printed Circuit Board (PCB) Replacement
Neye ihtiyacın var
  1. HTC Desire 700 Dual Sim Printed Circuit Board (PCB) Replacement, Back Cover: adım 1, 1 resimden 1.
    • Use the spudger to pry the back cover off.
  2. HTC Desire 700 Dual Sim Printed Circuit Board (PCB) Replacement, Removing Battery: adım 2, 1 resimden 1.
    • Use spudger tool to pry under the battery to lift it up and out.
  3. HTC Desire 700 Dual Sim Printed Circuit Board (PCB) Replacement, Remove 8 Torx Screws: adım 3, 1 resimden 1.
    • Remove eight 8.3mm T4 screws with the Torx screwdriver.
  4. HTC Desire 700 Dual Sim Printed Circuit Board (PCB) Replacement, Prying Off Rear Panel: adım 4, 1 resimden 1.
    • Pry the back panel of the screen using the plastic opener.
    • Work your way gently around the device, using picks as necessary to keep the back panel separated.
    • Use caution not to damage the device, as it takes force to remove the rear panel.
  5. HTC Desire 700 Dual Sim Printed Circuit Board (PCB) Replacement, Printed Circuit Board (PCB): adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Disconnect wire going from the printed circuit board to the motherboard using the tweezers.
  6. HTC Desire 700 Dual Sim Printed Circuit Board (PCB) Replacement: adım 6, 1 resimden 1.
    • Using the plastic prying tool, pry the PCB device from the screen of the phone.
Sonuç
Steven Pate
196 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-3, Blackwell Fall 2014 USF Tampa, Team 9-3, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S9G3
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 19
Her zaman: 2,138
