Ana içeriğe geç
HTC Desire 700 Dual Sim Rear Panel Replacement
Neye ihtiyacın var
  1. HTC Desire 700 Dual Sim Rear Panel Replacement, Back Cover: adım 1, 1 resimden 1.
    • Use the spudger to pry the back cover off.
  2. HTC Desire 700 Dual Sim Rear Panel Replacement, Removing Battery: adım 2, 1 resimden 1.
    • Use spudger tool to pry under the battery to lift it up and out.
  3. HTC Desire 700 Dual Sim Rear Panel Replacement, Remove 8 Torx Screws: adım 3, 1 resimden 1.
    • Remove eight 8.3mm T4 screws with the Torx screwdriver.
  4. HTC Desire 700 Dual Sim Rear Panel Replacement, Prying Off Rear Panel: adım 4, 1 resimden 1.
    • Pry the back panel of the screen using the plastic opener.
    • Work your way gently around the device, using picks as necessary to keep the back panel separated.
    • Use caution not to damage the device, as it takes force to remove the rear panel.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Steven Pate
196 İtibar
7 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 9-3, Blackwell Fall 2014 USF Tampa, Team 9-3, Blackwell Fall 2014 üyesi
USFT-BLACKWELL-F14S9G3
4 Üyeler
14 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 13
Her zaman: 1,407
