Ana içeriğe geç
HTC Desire 826 Screen Replacement
Neye ihtiyacın var
    1. HTC Desire 826 Screen Replacement, Battery: adım 1, 3 resimden 1. HTC Desire 826 Screen Replacement, Battery: adım 1, 3 resimden 2. HTC Desire 826 Screen Replacement, Battery: adım 1, 3 resimden 3.
      • Find a seam in the back of the device.
      • Insert the plastic spudger into the seam and pry off the back panel.
      • There will be glue, so keep prying until it comes off or you may need to heat up the edges of the device to loosen the adhesive with the iOpener.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Desire 826 Screen Replacement: adım 2, 3 resimden 1. HTC Desire 826 Screen Replacement: adım 2, 3 resimden 2. HTC Desire 826 Screen Replacement: adım 2, 3 resimden 3.
      Bu adımda kullanılan alet:
      • Remove the 4.0 mm screw above the battery with a T5 Torx screwdriver.
      • Remove the metal bracket with the tweezers.
      FixBot'a Sor
      Yorum Ekle
    3. HTC Desire 826 Screen Replacement: adım 3, 1 resimden 1.
      • Disconnect the battery cable from the motherboard with the tweezers.
      FixBot'a Sor
      Yorum Ekle
    4. HTC Desire 826 Screen Replacement: adım 4, 2 resimden 1. HTC Desire 826 Screen Replacement: adım 4, 2 resimden 2.
      • Lift the battery with a plastic spudger and remove it from the device.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Desire 826 Screen Replacement, Screen: adım 5, 2 resimden 1. HTC Desire 826 Screen Replacement, Screen: adım 5, 2 resimden 2.
      • Remove the two 4.0 mm screws attaching the bottom plastic panel using a T5 screwdriver.
      • Remove the black plastic cover using a plastic spudger
      FixBot'a Sor
      Yorum Ekle
    2. HTC Desire 826 Screen Replacement: adım 6, 1 resimden 1.
      • Use tweezers to pry the wire up from the battery bed
      • Detach the ribbon cable by pulling with the tweezers where circled in blue
      • Flip the phone over so the screen side is facing up for the next step
      FixBot'a Sor
      Yorum Ekle
    3. HTC Desire 826 Screen Replacement: adım 7, 2 resimden 1. HTC Desire 826 Screen Replacement: adım 7, 2 resimden 2.
      • Use the metal spudger to pry up the plastic cover pieces from the front of the phone
      FixBot'a Sor
      Yorum Ekle
    4. HTC Desire 826 Screen Replacement: adım 8, 2 resimden 1. HTC Desire 826 Screen Replacement: adım 8, 2 resimden 2.
      • Pry up the edges of the screen using the metal spudger
      • Then use the suction cup to remove the screen from your device
      • There will likely be glue holding your screen in place, so keep prying but be cautious not to break the screen. You may want to use the iOpener to loosen the adhesive prior to removal.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
1Rehber Yorum
Après avoir fait le démontage de l'écran , le digital est devenu très dur et ne réagi pas automatiquement au toucher . Que dois-je faire ?
Japhet piergy Bassa - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 41
Her zaman: 730
