Ana içeriğe geç
HTC Desire HTC Desire Speaker Replacement
Neye ihtiyacın var
  1. HTC Desire HTC Desire Speaker Replacement, Battery: adım 1, 2 resimden 1. HTC Desire HTC Desire Speaker Replacement, Battery: adım 1, 2 resimden 2.
    • Insert flat end of spudger into slot on the top of phone to pry off the back plate.
  2. HTC Desire HTC Desire Speaker Replacement: adım 2, 2 resimden 1. HTC Desire HTC Desire Speaker Replacement: adım 2, 2 resimden 2.
    • Use flat edge of spudger to lift the bottom right corner of the battery.
    • Lift the battery out of the phone.
  3. HTC Desire HTC Desire Speaker Replacement, Vibrator: adım 3, 1 resimden 1.
    • Remove the lower, two 0.5 mm screws using Torx T5 screwdriver.
  4. HTC Desire HTC Desire Speaker Replacement: adım 4, 2 resimden 1. HTC Desire HTC Desire Speaker Replacement: adım 4, 2 resimden 2.
    • Use spudger to pry vibrator panel off.
  5. HTC Desire HTC Desire Speaker Replacement: adım 5, 2 resimden 1. HTC Desire HTC Desire Speaker Replacement: adım 5, 2 resimden 2.
    • Use spudger to remove the vibrator.
  6. HTC Desire HTC Desire Speaker Replacement, HTC Desire Speaker: adım 6, 2 resimden 1. HTC Desire HTC Desire Speaker Replacement, HTC Desire Speaker: adım 6, 2 resimden 2.
    • Take out the upper, two 0.5 mm Torx screws with a Torx T5 bit.
  7. HTC Desire HTC Desire Speaker Replacement: adım 7, 1 resimden 1.
    • Take the middle 0.3 mm phillips screw out with the phillips J000 tip.
  8. HTC Desire HTC Desire Speaker Replacement: adım 8, 3 resimden 1. HTC Desire HTC Desire Speaker Replacement: adım 8, 3 resimden 2. HTC Desire HTC Desire Speaker Replacement: adım 8, 3 resimden 3.
    • Using the spudger, pry up to remove the battery holder.
  9. HTC Desire HTC Desire Speaker Replacement: adım 9, 3 resimden 1. HTC Desire HTC Desire Speaker Replacement: adım 9, 3 resimden 2. HTC Desire HTC Desire Speaker Replacement: adım 9, 3 resimden 3.
    • Using the spudger, pry the speaker out of its place.
  10. HTC Desire HTC Desire Speaker Replacement: adım 10, 1 resimden 1.
    • With the springs up, place the new speaker into position.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Scott Olson
274 İtibar
1 Kılavuz yazıldı
Ekip
Montana Tech, Team 10-2, Shirk Fall 2015 Montana Tech, Team 10-2, Shirk Fall 2015 üyesi
MTUM-SHIRK-F15S10G2
4 Üyeler
8 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 11
Her zaman: 1,178
