Ana içeriğe geç
HTC Droid DNA Front-Facing Camera Replacement
Neye ihtiyacın var
    1. HTC Droid DNA Front-Facing Camera Replacement, Remove the SIM Card Tray: adım 1, 1 resimden 1.
      • Poke a paperclip into the hole to the right of the SIM Card Tray. The SIM Card Tray will automatically pop out.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Droid DNA Front-Facing Camera Replacement, Removing the SIM Card Tray: adım 2, 2 resimden 1. HTC Droid DNA Front-Facing Camera Replacement, Removing the SIM Card Tray: adım 2, 2 resimden 2.
      • Pull out the SIM Card Tray with your fingers.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Droid DNA Front-Facing Camera Replacement, Loosen the Phone Casing: adım 3, 2 resimden 1. HTC Droid DNA Front-Facing Camera Replacement, Loosen the Phone Casing: adım 3, 2 resimden 2.
      • Make sure the USB cover on the bottom of the phone is removed first.
      • Starting at a corner, slowly work your way around the edge of the sides with your prying tool to loosen the front panel.
      • Take your time. A lot of force is necessary to loosen the front panel.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Droid DNA Front-Facing Camera Replacement, Pull the Casing Apart: adım 4, 1 resimden 1.
      • Slowly pull the panel apart from the back of the phone.
      • Apply a moderate force to pry the panel from the back of the phone.
      FixBot'a Sor
      Yorum Ekle
    3. HTC Droid DNA Front-Facing Camera Replacement, Remove the Black Tape: adım 5, 1 resimden 1.
      • Set the device down so that the bottom of the phone is facing to the right.
      • Gently take off the piece of black tape surrounding the motherboard.
      • Be careful not to rip the tape.
      FixBot'a Sor
      Yorum Ekle
    4. HTC Droid DNA Front-Facing Camera Replacement, Remove the Yellow Tape: adım 6, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Use your tweezers to take off the yellow tape on the bottom left corner of the phone.
      FixBot'a Sor
      Yorum Ekle
    5. HTC Droid DNA Front-Facing Camera Replacement: adım 7, 1 resimden 1.
      • Rotate your phone 90 degrees clockwise so the bottom of the phone is facing you.
      • Use the T5 Torx screwdriver to remove the two 4mm screws located at the bottom of the phone.
      FixBot'a Sor
      Yorum Ekle
    6. HTC Droid DNA Front-Facing Camera Replacement, Remove the Void Screw: adım 8, 1 resimden 1.
      • Use the Phillips #000 screwdriver to remove the single 2.7mm void screw on the bottom right.
      FixBot'a Sor
      Yorum Ekle
    7. HTC Droid DNA Front-Facing Camera Replacement, Remove the Screw Retaining Bracket: adım 9, 1 resimden 1.
      • Rotate your phone back 90 Degrees counter-clockwise.
      • Use your tweezers to take off the small metal retaining bracket on the bottom right of the phone.
      FixBot'a Sor
      Yorum Ekle
    8. HTC Droid DNA Front-Facing Camera Replacement, Remove the Connector Screws: adım 10, 1 resimden 1.
      • Remove the following Phillips #000 screws from the motherboard:
      • Four 1.6 mm screws
      • Two 1.5 mm screws
      FixBot'a Sor
      Yorum Ekle
    9. HTC Droid DNA Front-Facing Camera Replacement, Unfasten the Connectors: adım 11, 2 resimden 1. HTC Droid DNA Front-Facing Camera Replacement, Unfasten the Connectors: adım 11, 2 resimden 2.
      • Use your pry tool to unfasten the connectors on both sides of the motherboard.
      • The connectors will still be attached to the green camera board at the top so DO NOT try to pull them off or bend them severely.
      FixBot'a Sor
      Yorum Ekle
    10. HTC Droid DNA Front-Facing Camera Replacement, Remove the Yellow Tape: adım 12, 1 resimden 1.
      • Use your tweezers to remove the two pieces of yellow tape shown.
      FixBot'a Sor
      Yorum Ekle
    11. HTC Droid DNA Front-Facing Camera Replacement, Flipping up the White Board: adım 13, 2 resimden 1. HTC Droid DNA Front-Facing Camera Replacement, Flipping up the White Board: adım 13, 2 resimden 2.
      • Use your tweezers to gently snap up the white board on the bottom right of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    12. HTC Droid DNA Front-Facing Camera Replacement, Disconnect the Connector: adım 14, 1 resimden 1.
      • Use your tweezers to disconnect the black connector on the bottom right of the motherboard.
      • Be careful not to bend the Flex Cable of the Connector.
      FixBot'a Sor
      Yorum Ekle
    13. HTC Droid DNA Front-Facing Camera Replacement, Flipping up the White Board: adım 15, 2 resimden 1. HTC Droid DNA Front-Facing Camera Replacement, Flipping up the White Board: adım 15, 2 resimden 2.
      • Use your tweezers to gently snap the other white board on the bottom right of the motherboard up.
      FixBot'a Sor
      Yorum Ekle
    14. HTC Droid DNA Front-Facing Camera Replacement, Disconnect the Connector: adım 16, 1 resimden 1.
      • Use your tweezers to disconnect the other small connector on the bottom right of the motherboard.
      • Be careful not to bend the Flex Cables for the Connector.
      FixBot'a Sor
      Yorum Ekle
    15. HTC Droid DNA Front-Facing Camera Replacement, Flipping up the White Board: adım 17, 2 resimden 1. HTC Droid DNA Front-Facing Camera Replacement, Flipping up the White Board: adım 17, 2 resimden 2.
      • Rotate the phone 180 degrees.
      • Use your tweezers to gently snap up the white board on the top left of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    16. HTC Droid DNA Front-Facing Camera Replacement, Disconnect the Connector: adım 18, 1 resimden 1.
      • Use your tweezers to disconnect the cable on the top left of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    17. HTC Droid DNA Front-Facing Camera Replacement, Flipping up the Black Board: adım 19, 2 resimden 1. HTC Droid DNA Front-Facing Camera Replacement, Flipping up the Black Board: adım 19, 2 resimden 2.
      • Use your tweezers to gently snap up the black board on the top left of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    18. HTC Droid DNA Front-Facing Camera Replacement, Disconnect the Small Ribbon Connector: adım 20, 1 resimden 1.
      • Use your tweezers to gently remove the yellow connector on the top left of the phone.
      FixBot'a Sor
      Yorum Ekle
    19. HTC Droid DNA Front-Facing Camera Replacement, Remove the Black Wire: adım 21, 1 resimden 1.
      • Remove the long black wire on the left of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    20. HTC Droid DNA Front-Facing Camera Replacement, Remove the Two Black Wires: adım 22, 1 resimden 1.
      • Reorient the phone so that the green camera board is farthest from you.
      • Use your tweezers to remove the two wires located at the top of the board. The wires snap off very easily so not much force is needed.
      FixBot'a Sor
      Yorum Ekle
    21. HTC Droid DNA Front-Facing Camera Replacement, Remove the Screws: adım 23, 1 resimden 1.
      • Use a Phillips #000 screwdriver to remove the two 3.9mm screws on top of motherboard.
      FixBot'a Sor
      Yorum Ekle
    22. HTC Droid DNA Front-Facing Camera Replacement, Remove the Motherboard: adım 24, 2 resimden 1. HTC Droid DNA Front-Facing Camera Replacement, Remove the Motherboard: adım 24, 2 resimden 2.
      • Now, use your fingers to slowly pull up the motherboard and remove it from the phone.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Droid DNA Front-Facing Camera Replacement, Remove Screws: adım 25, 1 resimden 1.
      • Use a Phillips #000 screwdriver to remove the two 2.1mm screws on the top of the camera board.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Droid DNA Front-Facing Camera Replacement, Loosen the Adhesive: adım 26, 2 resimden 1. HTC Droid DNA Front-Facing Camera Replacement, Loosen the Adhesive: adım 26, 2 resimden 2.
      • Use the pry tool along the bottom and sides of the camera board to loosen the adhesive.
      • The power button and headphone jack need to be carefully removed with the camera board or they could snap off of the camera board.
      FixBot'a Sor
      Yorum Ekle
    3. HTC Droid DNA Front-Facing Camera Replacement, Remove Camera Board: adım 27, 1 resimden 1.
      • Slowly lift the camera board up and work on removing the remaining adhesive. You can then take the camera board off of the phone.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Droid DNA Front-Facing Camera Replacement, Remove Yellow Tape: adım 28, 1 resimden 1.
      • Use your tweezers to gently remove the yellow tape on the far left side of the camera board.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Droid DNA Front-Facing Camera Replacement, Release the White Connector Clip: adım 29, 2 resimden 1. HTC Droid DNA Front-Facing Camera Replacement, Release the White Connector Clip: adım 29, 2 resimden 2.
      • Use your tweezers to gently flip the white connector clip into the upright position.
      FixBot'a Sor
      Yorum Ekle
    3. HTC Droid DNA Front-Facing Camera Replacement, Remove Front-Facing Camera: adım 30, 1 resimden 1.
      • Use your tweezers to gently pull the front facing camera off the camera board.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Adrian Williams
585 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-43, Amido Fall 2014 Cal Poly, Team 4-43, Amido Fall 2014 üyesi
CPSU-AMIDO-F14S4G43
4 Üyeler
28 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 18
Her zaman: 1,424
