Ana içeriğe geç
HTC Droid DNA Micro USB Port Replacement
Neye ihtiyacın var
  1. HTC Droid DNA Micro USB Port Replacement, Remove the SIM Card Tray: adım 1, 1 resimden 1.
    • Poke a paperclip into the hole to the right of the SIM Card Tray. The SIM Card Tray will automatically pop out.
  2. HTC Droid DNA Micro USB Port Replacement, Removing the SIM Card Tray: adım 2, 2 resimden 1. HTC Droid DNA Micro USB Port Replacement, Removing the SIM Card Tray: adım 2, 2 resimden 2.
    • Pull out the SIM Card Tray with your fingers.
  3. HTC Droid DNA Micro USB Port Replacement, Loosen the Phone Casing: adım 3, 2 resimden 1. HTC Droid DNA Micro USB Port Replacement, Loosen the Phone Casing: adım 3, 2 resimden 2.
    • Make sure the USB cover on the bottom of the phone is removed first.
    • Starting at a corner, slowly work your way around the edge of the sides with your prying tool to loosen the front panel.
    • Take your time. A lot of force is necessary to loosen the front panel.
  4. HTC Droid DNA Micro USB Port Replacement, Pull the Casing Apart: adım 4, 1 resimden 1.
    • Slowly pull the panel apart from the back of the phone.
    • Apply a moderate force to pry the panel from the back of the phone.
  5. HTC Droid DNA Micro USB Port Replacement, Remove the Black Tape: adım 5, 1 resimden 1.
    • Set the device down so that the bottom of the phone is facing to the right.
    • Gently take off the piece of black tape surrounding the motherboard.
    • Be careful not to rip the tape.
  6. HTC Droid DNA Micro USB Port Replacement, Remove the Yellow Tape: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use your tweezers to take off the yellow tape on the bottom left corner of the phone.
  7. HTC Droid DNA Micro USB Port Replacement: adım 7, 1 resimden 1.
    • Rotate your phone 90 degrees clockwise so the bottom of the phone is facing you.
    • Use the T5 Torx screwdriver to remove the two 4mm screws located at the bottom of the phone.
  8. HTC Droid DNA Micro USB Port Replacement, Remove the Void Screw: adım 8, 1 resimden 1.
    • Use the Phillips #000 screwdriver to remove the single 2.7mm void screw on the bottom right.
  9. HTC Droid DNA Micro USB Port Replacement, Remove the Screw Retaining Bracket: adım 9, 1 resimden 1.
    • Rotate your phone back 90 Degrees counter-clockwise.
    • Use your tweezers to take off the small metal retaining bracket on the bottom right of the phone.
  10. HTC Droid DNA Micro USB Port Replacement, Remove the Connector Screws: adım 10, 1 resimden 1.
    • Remove the following Phillips #000 screws from the motherboard:
    • Four 1.6 mm screws
    • Two 1.5 mm screws
  11. HTC Droid DNA Micro USB Port Replacement, Unfasten the Connectors: adım 11, 2 resimden 1. HTC Droid DNA Micro USB Port Replacement, Unfasten the Connectors: adım 11, 2 resimden 2.
    • Use your pry tool to unfasten the connectors on both sides of the motherboard.
    • The connectors will still be attached to the green camera board at the top so DO NOT try to pull them off or bend them severely.
  12. HTC Droid DNA Micro USB Port Replacement, Remove the Yellow Tape: adım 12, 1 resimden 1.
    • Use your tweezers to remove the two pieces of yellow tape shown.
  13. HTC Droid DNA Micro USB Port Replacement, Flipping up the White Board: adım 13, 2 resimden 1. HTC Droid DNA Micro USB Port Replacement, Flipping up the White Board: adım 13, 2 resimden 2.
    • Use your tweezers to gently snap up the white board on the bottom right of the motherboard.
  14. HTC Droid DNA Micro USB Port Replacement, Disconnect the Connector: adım 14, 1 resimden 1.
    • Use your tweezers to disconnect the black connector on the bottom right of the motherboard.
    • Be careful not to bend the Flex Cable of the Connector.
  15. HTC Droid DNA Micro USB Port Replacement, Flipping up the White Board: adım 15, 2 resimden 1. HTC Droid DNA Micro USB Port Replacement, Flipping up the White Board: adım 15, 2 resimden 2.
    • Use your tweezers to gently snap the other white board on the bottom right of the motherboard up.
  16. HTC Droid DNA Micro USB Port Replacement, Disconnect the Connector: adım 16, 1 resimden 1.
    • Use your tweezers to disconnect the other small connector on the bottom right of the motherboard.
    • Be careful not to bend the Flex Cables for the Connector.
  17. HTC Droid DNA Micro USB Port Replacement, Flipping up the White Board: adım 17, 2 resimden 1. HTC Droid DNA Micro USB Port Replacement, Flipping up the White Board: adım 17, 2 resimden 2.
    • Rotate the phone 180 degrees.
    • Use your tweezers to gently snap up the white board on the top left of the motherboard.
  18. HTC Droid DNA Micro USB Port Replacement, Disconnect the Connector: adım 18, 1 resimden 1.
    • Use your tweezers to disconnect the cable on the top left of the motherboard.
  19. HTC Droid DNA Micro USB Port Replacement, Flipping up the Black Board: adım 19, 2 resimden 1. HTC Droid DNA Micro USB Port Replacement, Flipping up the Black Board: adım 19, 2 resimden 2.
    • Use your tweezers to gently snap up the black board on the top left of the motherboard.
  20. HTC Droid DNA Micro USB Port Replacement, Disconnect the Small Ribbon Connector: adım 20, 1 resimden 1.
    • Use your tweezers to gently remove the yellow connector on the top left of the phone.
  21. HTC Droid DNA Micro USB Port Replacement, Remove the Black Wire: adım 21, 1 resimden 1.
    • Remove the long black wire on the left of the motherboard.
  22. HTC Droid DNA Micro USB Port Replacement, Remove the Two Black Wires: adım 22, 1 resimden 1.
    • Reorient the phone so that the green camera board is farthest from you.
    • Use your tweezers to remove the two wires located at the top of the board. The wires snap off very easily so not much force is needed.
  23. HTC Droid DNA Micro USB Port Replacement, Remove the Screws: adım 23, 1 resimden 1.
    • Use a Phillips #000 screwdriver to remove the two 3.9mm screws on top of motherboard.
  24. HTC Droid DNA Micro USB Port Replacement, Remove the Motherboard: adım 24, 2 resimden 1. HTC Droid DNA Micro USB Port Replacement, Remove the Motherboard: adım 24, 2 resimden 2.
    • Now, use your fingers to slowly pull up the motherboard and remove it from the phone.
  25. HTC Droid DNA Micro USB Port Replacement, Remove the Charging Port Assembly: adım 25, 2 resimden 1. HTC Droid DNA Micro USB Port Replacement, Remove the Charging Port Assembly: adım 25, 2 resimden 2.
    • Use the plastic prying tool to gently remove the charging port assembly.
  26. HTC Droid DNA Micro USB Port Replacement, Disassemble Charging Port Assembly: adım 26, 1 resimden 1.
    • Use a Phillips #000 screw driver to remove the single 2.1mm screw located on the backside of the assembly.
  27. HTC Droid DNA Micro USB Port Replacement, Undo the Wire Connection: adım 27, 2 resimden 1. HTC Droid DNA Micro USB Port Replacement, Undo the Wire Connection: adım 27, 2 resimden 2.
    • Use your tweezers to undo the red and black wire connection.
  28. HTC Droid DNA Micro USB Port Replacement, Separate the Black and Blue Assembly Pieces: adım 28, 3 resimden 1. HTC Droid DNA Micro USB Port Replacement, Separate the Black and Blue Assembly Pieces: adım 28, 3 resimden 2. HTC Droid DNA Micro USB Port Replacement, Separate the Black and Blue Assembly Pieces: adım 28, 3 resimden 3.
    • Use the plastic prying tool to separate the assembly into two pieces: blue and black.
  29. HTC Droid DNA Micro USB Port Replacement, Remove the wire: adım 29, 2 resimden 1. HTC Droid DNA Micro USB Port Replacement, Remove the wire: adım 29, 2 resimden 2.
    • Remove the black wire on the blue piece (the Micro USB charging port) so it is out of the way and cannot get damaged.
    • If the micro USB port is damaged, the charging port may need to be replaced.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Madeline Tran
707 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 4-43, Amido Fall 2014 Cal Poly, Team 4-43, Amido Fall 2014 üyesi
CPSU-AMIDO-F14S4G43
4 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 5
Her zaman: 2,485
