Ana içeriğe geç
HTC Droid Eris Battery Replacement
Neye ihtiyacın var
    1. HTC Droid Eris Battery Replacement, Battery: adım 1, 2 resimden 1. HTC Droid Eris Battery Replacement, Battery: adım 1, 2 resimden 2.
      • Place the device on a flat surface with the headphone outlet/jack facing away from you.
      • Place one of your fingers on the opposite corner of the headphone outlet/jack where there is a sliver of space. Be sure not to touch the front screen.
      • Next, pull the back cover upwards and off. If this feels difficult, use the spudger, and wedge it between the covers to pry off.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Droid Eris Battery Replacement: adım 2, 2 resimden 1. HTC Droid Eris Battery Replacement: adım 2, 2 resimden 2.
      • Once the cover is off, lay the device on a flat surface with the screen facing downward. Use one hand to hold the device in place with the half-moon gap facing away from you [marked].
      • The square piece in the center of the phone is the battery. With your free hand, stick one of your fingers in the marked gap. Pull gently upwards towards you to remove.
      • If the battery is not coming out with this technique, use the iFixit plastic opening tool to pop it out of its holdings.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Elizabeth Ofori
648 İtibar
6 adet Kılavuz yazıldı
Ekip
SUNY Cortland, Team 1-2, Getto Spring 2013 SUNY Cortland, Team 1-2, Getto Spring 2013 üyesi
SUNYCORT-GETTO-S13S1G2
5 Üyeler
42 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 32
Her zaman: 1,126
