Ana içeriğe geç
HTC Droid Eris Midframe Replacement
Neye ihtiyacın var
    1. HTC Droid Eris Midframe Replacement, Battery: adım 1, 2 resimden 1. HTC Droid Eris Midframe Replacement, Battery: adım 1, 2 resimden 2.
      • Place the device on a flat surface with the headphone outlet/jack facing away from you.
      • Place one of your fingers on the opposite corner of the headphone outlet/jack where there is a sliver of space. Be sure not to touch the front screen.
      • Next, pull the back cover upwards and off. If this feels difficult, use the spudger, and wedge it between the covers to pry off.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Droid Eris Midframe Replacement: adım 2, 2 resimden 1. HTC Droid Eris Midframe Replacement: adım 2, 2 resimden 2.
      • Once the cover is off, lay the device on a flat surface with the screen facing downward. Use one hand to hold the device in place with the half-moon gap facing away from you [marked].
      • The square piece in the center of the phone is the battery. With your free hand, stick one of your fingers in the marked gap. Pull gently upwards towards you to remove.
      • If the battery is not coming out with this technique, use the iFixit plastic opening tool to pop it out of its holdings.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Droid Eris Midframe Replacement, Midframe: adım 3, 2 resimden 1. HTC Droid Eris Midframe Replacement, Midframe: adım 3, 2 resimden 2.
      • At the lower right hand corner of the phone use one hand to hold the device in place and use your finger to push the micro SD card inwards until you hear a "click" sound and it pops out.
      • If that method is difficult, use the plastic opening tool or spudger to push the micro SD card inwards and it will make a "click" sound and pop out.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Droid Eris Midframe Replacement: adım 4, 2 resimden 1. HTC Droid Eris Midframe Replacement: adım 4, 2 resimden 2.
      • Use the T4 screwdriver to remove the three .05 mm screws from the back cover.
      FixBot'a Sor
      Yorum Ekle
    3. HTC Droid Eris Midframe Replacement: adım 5, 2 resimden 1. HTC Droid Eris Midframe Replacement: adım 5, 2 resimden 2.
      • Use the plastic opening tool and place it in the gap by the chrome bezels which are located on both sides of the device. Pull the plastic opening tool to pry plastic case apart. Start prying open the device and work around the seam of the phone in a clockwise direction.
      • DON’T BREAK THE CLIPS (you can damage the frame this way). Pry it gently until you hear it click and start to see it open.
      • Remove the midframe.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Elizabeth Ofori
648 İtibar
6 adet Kılavuz yazıldı
Ekip
SUNY Cortland, Team 1-2, Getto Spring 2013 SUNY Cortland, Team 1-2, Getto Spring 2013 üyesi
SUNYCORT-GETTO-S13S1G2
5 Üyeler
72 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 22
Son 30 gün: 59
Her zaman: 789
