Eksik Adımlar
Hata! Bu kılavuzda şu anda bir veya daha fazla önemli adım eksik.
Giriş
1. adıma git ↓With this phone, the LCD and digitizer are removed together. These can then be separated by heating. If there is a discrepancy with the way images appear on your screen you may have a broken LCD. However, if you are unable to utilize the touchscreen interface then you may have a broken digitizer.
Neye ihtiyacın var
Aletler
Spudger4.9
Use the plastic opening tool to pry off back cover by inserting opening tool in the space indicated and pushing down on the handle of the tool.
5 farklı kişi bu kılavuzu tamamladı.
