Ana içeriğe geç
HTC Droid Incredible 4G LTE Micro USB Port Replacement
Neye ihtiyacın var
  1. HTC Droid Incredible 4G LTE Micro USB Port Replacement, Battery: adım 1, 1 resimden 1.
    • Use the plastic opening tool to pry off back cover by inserting opening tool in the space indicated and pushing down on the handle of the tool.
    FixBot'a Sor
    Yorum Ekle
  2. HTC Droid Incredible 4G LTE Micro USB Port Replacement: adım 2, 1 resimden 1.
    • Remove the battery after taking off the cover.
    FixBot'a Sor
    Yorum Ekle
  3. HTC Droid Incredible 4G LTE Micro USB Port Replacement, Midframe: adım 3, 1 resimden 1.
    • Remove eight 4mm and one 5mm Torx screws.
    FixBot'a Sor
    Yorum Ekle
  4. HTC Droid Incredible 4G LTE Micro USB Port Replacement: adım 4, 2 resimden 1. HTC Droid Incredible 4G LTE Micro USB Port Replacement: adım 4, 2 resimden 2.
    • Use a prying tool to pry off the midframe.
    FixBot'a Sor
    Yorum Ekle
  5. HTC Droid Incredible 4G LTE Micro USB Port Replacement, Micro USB Port: adım 5, 1 resimden 1.
    • Remove the 4mm Torx screw holding the charging port to the phone.
    FixBot'a Sor
    Yorum Ekle
  6. HTC Droid Incredible 4G LTE Micro USB Port Replacement: adım 6, 1 resimden 1.
    • Remove the silver bracket holding the charging port in place.
    FixBot'a Sor
    Yorum Ekle
  7. HTC Droid Incredible 4G LTE Micro USB Port Replacement: adım 7, 1 resimden 1.
    • Use a prying tool to remove the charging port as shown.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Tevin
666 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 15-1, Remmell Fall 2014 USF Tampa, Team 15-1, Remmell Fall 2014 üyesi
USFT-REMMELL-F14S15G1
4 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 29
Her zaman: 1,130
