Ana içeriğe geç
HTC Droid Incredible Battery Replacement
  1. HTC Droid Incredible Battery Replacement, Battery: adım 1, 3 resimden 1. HTC Droid Incredible Battery Replacement, Battery: adım 1, 3 resimden 2. HTC Droid Incredible Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Press your thumbnail into the slot between the rear panel and the front case located in the bottom of the phone.
    • Useful tip: a penny or dime works in a pinch if you can't use your thumbnail.
    • Gently pry the rear panel up and away from the phone. You may need to slide your thumb up the crack to separate the rear panel from the front case.
  2. HTC Droid Incredible Battery Replacement: adım 2, 1 resimden 1.
    • Remove the rear panel from the phone.
  3. HTC Droid Incredible Battery Replacement: adım 3, 3 resimden 1. HTC Droid Incredible Battery Replacement: adım 3, 3 resimden 2. HTC Droid Incredible Battery Replacement: adım 3, 3 resimden 3.
    • Insert a fingertip into the gap between the battery and the rear inner frame, located between the battery and the speaker. Slide the battery away from the speaker, widening the gap.
    • Lift the top of the battery up and remove the battery from the rear inner frame.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Andrew Optimus Goldheart
509.065 İtibar
407 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
118 Üyeler
19.656 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 1,620
