Ana içeriğe geç
HTC EVO 4G Speaker Replacement
Neye ihtiyacın var
  1. HTC EVO 4G Speaker Replacement, Battery: adım 1, 2 resimden 1. HTC EVO 4G Speaker Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the back case of the phone with a plastic opening tool by placing the tool in the tab on the back of the phone.
  2. HTC EVO 4G Speaker Replacement: adım 2, 2 resimden 1. HTC EVO 4G Speaker Replacement: adım 2, 2 resimden 2.
    • Remove the battery from the phone by carefully lifting it out with your fingers.
  3. HTC EVO 4G Speaker Replacement: adım 3, 1 resimden 1.
    • Set the battery aside for disposal. You are now ready to insert a new battery.
  4. HTC EVO 4G Speaker Replacement, Speaker: adım 4, 1 resimden 1.
    • you should remove the six T5 screws holding the Inner frame in place. Be careful not to loose the screws
  5. HTC EVO 4G Speaker Replacement: adım 5, 3 resimden 1. HTC EVO 4G Speaker Replacement: adım 5, 3 resimden 2. HTC EVO 4G Speaker Replacement: adım 5, 3 resimden 3.
    • Using the plastic opening tool again, gently pry the inner frame apart from the rest of the phone
    • Remove the inner frame from the rest of the phone by lifting it off
  6. HTC EVO 4G Speaker Replacement: adım 6, 1 resimden 1.
    • use plastic pic to gently pry our the speaker
    • be sure to have your replacement unit ready
Sonuç
Sage Jurado
1.128 İtibar
4 adet Kılavuz yazıldı
Ekip
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 295
