Ana içeriğe geç
HTC EVO 4G Stand Replacement
Neye ihtiyacın var
  1. HTC EVO 4G Stand Replacement, Battery: adım 1, 2 resimden 1. HTC EVO 4G Stand Replacement, Battery: adım 1, 2 resimden 2.
    • Remove the back case of the phone with a plastic opening tool by placing the tool in the tab on the back of the phone.
  2. HTC EVO 4G Stand Replacement: adım 2, 2 resimden 1. HTC EVO 4G Stand Replacement: adım 2, 2 resimden 2.
    • Remove the battery from the phone by carefully lifting it out with your fingers.
  3. HTC EVO 4G Stand Replacement: adım 3, 1 resimden 1.
    • Set the battery aside for disposal. You are now ready to insert a new battery.
  4. HTC EVO 4G Stand Replacement, Stand: adım 4, 1 resimden 1.
    • you should remove the six T5 screws holding the Inner frame in place. Be careful not to loose the screws
  5. HTC EVO 4G Stand Replacement: adım 5, 3 resimden 1. HTC EVO 4G Stand Replacement: adım 5, 3 resimden 2. HTC EVO 4G Stand Replacement: adım 5, 3 resimden 3.
    • Using the plastic opening tools again, gently pry the inner frame apart from the rest of the phone
    • Remove the inner frame from the rest of the phone by lifting it off
  6. HTC EVO 4G Stand Replacement: adım 6, 1 resimden 1.
    • Remove the five screws that are holding the stand in place.
  7. HTC EVO 4G Stand Replacement: adım 7, 1 resimden 1.
    • Remove the stand from the frame by lifting it out. Clear any debis causing it to be jammed, or replace with new stand.
Sonuç
Sage Jurado
1.128 İtibar
4 adet Kılavuz yazıldı
Ekip
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 8
Her zaman: 153
