Ana içeriğe geç
HTC Evo 3D Speaker Replacement
Neye ihtiyacın var
  1. HTC Evo 3D Speaker Replacement, Speaker: adım 1, 3 resimden 1. HTC Evo 3D Speaker Replacement, Speaker: adım 1, 3 resimden 2. HTC Evo 3D Speaker Replacement, Speaker: adım 1, 3 resimden 3.
    • Remove the outer casing of the phone with your hands by prying and lifting at the latch.
  2. HTC Evo 3D Speaker Replacement: adım 2, 2 resimden 1. HTC Evo 3D Speaker Replacement: adım 2, 2 resimden 2.
    • Remove the battery with your hands, lifting at the marked area.
    • Remove the SD card by pulling down on the bottom of the card.
  3. HTC Evo 3D Speaker Replacement: adım 3, 1 resimden 1.
    • Remove the four T5 screws using the cooresponding screwdriver.
    • Remove the two J000 screws using the cooresponding screwdriver.
  4. HTC Evo 3D Speaker Replacement: adım 4, 2 resimden 1. HTC Evo 3D Speaker Replacement: adım 4, 2 resimden 2.
    • With the battery removed, the inner case of the phone can now be removed.
    • Using the plastic opening tool, pry the inner case off at the marked area. Continue prying around the entire perimeter of the phone.
    • This will remove the inner case, and allow access into the inner portion of the phone.
    • The marked part in the second photo is the speaker.
  5. HTC Evo 3D Speaker Replacement: adım 5, 3 resimden 1. HTC Evo 3D Speaker Replacement: adım 5, 3 resimden 2. HTC Evo 3D Speaker Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • The speaker can be loosened from its glue with the spudger.
    • Pry from the bottom with constant pressure to loosen one end of the speaker.
    • When the speaker is sufficiently loosened, completely remove it by grabbing it with the precision tweezers.
  6. HTC Evo 3D Speaker Replacement: adım 6, 1 resimden 1.
    • With the old speaker removed, insert the new speaker in the same place.
    • When reinserting the new speaker, be sure that the golden contacts (As previously marked) are facing up.
Sonuç
To reassemble your device, follow these instructions in reverse order but with a new speaker.
Bir başkası bu kılavuzu tamamladı.
James Burke
245 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 14-20, Meier Fall 2015 USF Tampa, Team 14-20, Meier Fall 2015 üyesi
USFT-MEIER-F15S14G20
5 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 335
