Giriş
In this guide, we will show the steps necessary to replace the speaker in the HTC Evo 3D. This guide will help to restore audio from the rear speaker.
Neye ihtiyacın var
Remove the outer casing of the phone with your hands by prying and lifting at the latch.
With the battery removed, the inner case of the phone can now be removed.
Using the plastic opening tool, pry the inner case off at the marked area. Continue prying around the entire perimeter of the phone.
This will remove the inner case, and allow access into the inner portion of the phone.
The marked part in the second photo is the speaker.
Bu adımda kullanılan alet:Tweezers$4.99
The speaker can be loosened from its glue with the spudger.
Pry from the bottom with constant pressure to loosen one end of the speaker.
When the speaker is sufficiently loosened, completely remove it by grabbing it with the precision tweezers.
To reassemble your device, follow these instructions in reverse order but with a new speaker.
Bir başkası bu kılavuzu tamamladı.
