Ana içeriğe geç
HTC Evo 3D Vibrate Mechanism Replacement
Neye ihtiyacın var
  1. HTC Evo 3D Vibrate Mechanism Replacement, Vibrate Mechanism: adım 1, 3 resimden 1. HTC Evo 3D Vibrate Mechanism Replacement, Vibrate Mechanism: adım 1, 3 resimden 2. HTC Evo 3D Vibrate Mechanism Replacement, Vibrate Mechanism: adım 1, 3 resimden 3.
    • Remove the outer casing of the phone with your hands by prying and lifting at the latch.
  2. HTC Evo 3D Vibrate Mechanism Replacement: adım 2, 2 resimden 1. HTC Evo 3D Vibrate Mechanism Replacement: adım 2, 2 resimden 2.
    • Remove the battery with your hands, lifting at the marked area.
  3. HTC Evo 3D Vibrate Mechanism Replacement: adım 3, 1 resimden 1.
    • Remove the SD card
    • Remove the four T5 screws using the corresponding screwdriver.
    • Remove the two J000 screws using the corresponding screwdriver.
  4. HTC Evo 3D Vibrate Mechanism Replacement: adım 4, 2 resimden 1. HTC Evo 3D Vibrate Mechanism Replacement: adım 4, 2 resimden 2.
    • With the battery removed, the inner case of the phone can now be removed.
    • Using the plastic opening tool, pry the inner case off at the marked area. Continue prying around the entire perimeter of the phone.
    • This will remove the inner case, and allow access into the inner portion of the phone.
    • Be careful not rip or damage the ribbons inside this shell.
  5. HTC Evo 3D Vibrate Mechanism Replacement: adım 5, 3 resimden 1. HTC Evo 3D Vibrate Mechanism Replacement: adım 5, 3 resimden 2. HTC Evo 3D Vibrate Mechanism Replacement: adım 5, 3 resimden 3.
    Bu adımda kullanılan alet:
    • The vibrating mechanism is located on the motherboard, on the right.
    • The marked part is the vibrating mechanism.
    • To remove the vibrating mechanism, use the tweezers to securely hold the wire and tug on it.
    • The vibrating unit can then be disconnected from the motherboard using the tweezers, grasping the white part.
Sonuç
James Burke
245 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 14-20, Meier Fall 2015 USF Tampa, Team 14-20, Meier Fall 2015 üyesi
USFT-MEIER-F15S14G20
5 Üyeler
10 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 374
