Ana içeriğe geç
HTC Evo 4G Dual LED Flash Replacement
Neye ihtiyacın var
    1. HTC Evo 4G Dual LED Flash Replacement, Rear Panel: adım 1, 1 resimden 1.
      • Gently insert an iPod opening tool between the rear panel and the inner rear frame near the headphone jack.
      • Use your iPod opening tool to pry up the rear case around the perimeter of the Evo.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Evo 4G Dual LED Flash Replacement: adım 2, 1 resimden 1.
      • Lift the rear panel off of the inner rear frame.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Evo 4G Dual LED Flash Replacement, Battery: adım 3, 2 resimden 1. HTC Evo 4G Dual LED Flash Replacement, Battery: adım 3, 2 resimden 2.
      • Using the tip of your finger, lift the battery from the end closest to the camera.
      • Remove the battery from the rear inner frame.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Evo 4G Dual LED Flash Replacement, MicroSD card: adım 4, 1 resimden 1.
      • Use the flat end of a spudger to pry up the red MicroSD retainer attached to the inner frame.
      • The retainer will move about 1 mm and stop. Do not attempt to completely remove the MicroSD card retainer.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Evo 4G Dual LED Flash Replacement: adım 5, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Use a pair of tweezers to carefully pull the MicroSD card out of its slot in the inner rear frame.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Evo 4G Dual LED Flash Replacement, Rear Inner Frame: adım 6, 1 resimden 1.
      • Remove six T5 Torx screws securing the rear inner frame to the inner case.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Evo 4G Dual LED Flash Replacement: adım 7, 1 resimden 1.
      • Gently insert an iPod opening tool between the rear inner frame and its plastic surround near the Micro HDMI port.
      • Carefully pry the top edge of the rear inner frame away from the front surround of the Evo.
      FixBot'a Sor
      Yorum Ekle
    3. HTC Evo 4G Dual LED Flash Replacement: adım 8, 2 resimden 1. HTC Evo 4G Dual LED Flash Replacement: adım 8, 2 resimden 2.
      • Insert the iPod opening tool between the rear inner frame and its plastic surround and pry up at several points along the left edge of the Evo.
      FixBot'a Sor
      Yorum Ekle
    4. HTC Evo 4G Dual LED Flash Replacement: adım 9, 3 resimden 1. HTC Evo 4G Dual LED Flash Replacement: adım 9, 3 resimden 2. HTC Evo 4G Dual LED Flash Replacement: adım 9, 3 resimden 3.
      • Continue the prying procedure, now focusing on detaching the plastic surround from the bottom of the Evo.
      • Pry up the rear inner frame along the right edge using the method described in previous steps.
      • Eventually work around the entire perimeter of the rear inner frame until it is lifted slightly from the inner case.
      FixBot'a Sor
      Yorum Ekle
    5. HTC Evo 4G Dual LED Flash Replacement: adım 10, 1 resimden 1.
      • Remove the rear inner frame from the rest of the Evo.
      FixBot'a Sor
      Yorum Ekle
    1. HTC Evo 4G Dual LED Flash Replacement, Dual LED Flash: adım 11, 1 resimden 1.
      • Remove the two Phillips screws securing the dual LED flash assembly to the rear inner frame.
      FixBot'a Sor
      Yorum Ekle
    2. HTC Evo 4G Dual LED Flash Replacement: adım 12, 1 resimden 1.
      • Use an iPod opening tool to pry the dual LED flash assembly off the posts securing it to the rear inner frame.
      • Remove the dual LED flash unit from the rear inner frame.
      FixBot'a Sor
      Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 41
Her zaman: 15,939
