Ana içeriğe geç
HTC Evo 4G Front Panel Replacement
Neye ihtiyacın var
  1. HTC Evo 4G Front Panel Replacement, Rear Panel: adım 1, 1 resimden 1.
    • Gently insert an iPod opening tool between the rear panel and the inner rear frame near the headphone jack.
    • Use your iPod opening tool to pry up the rear case around the perimeter of the Evo.
    FixBot'a Sor
    Yorum Ekle
  2. HTC Evo 4G Front Panel Replacement: adım 2, 1 resimden 1.
    • Lift the rear panel off of the inner rear frame.
    FixBot'a Sor
    Yorum Ekle
  3. HTC Evo 4G Front Panel Replacement, Battery: adım 3, 2 resimden 1. HTC Evo 4G Front Panel Replacement, Battery: adım 3, 2 resimden 2.
    • Using the tip of your finger, lift the battery from the end closest to the camera.
    • Remove the battery from the rear inner frame.
    FixBot'a Sor
    Yorum Ekle
  4. HTC Evo 4G Front Panel Replacement, MicroSD card: adım 4, 1 resimden 1.
    • Use the flat end of a spudger to pry up the red MicroSD retainer attached to the inner frame.
    • The retainer will move about 1 mm and stop. Do not attempt to completely remove the MicroSD card retainer.
    FixBot'a Sor
    Yorum Ekle
  5. HTC Evo 4G Front Panel Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers to carefully pull the MicroSD card out of its slot in the inner rear frame.
    FixBot'a Sor
    Yorum Ekle
  6. HTC Evo 4G Front Panel Replacement, Rear Inner Frame: adım 6, 1 resimden 1.
    • Remove six T5 Torx screws securing the rear inner frame to the inner case.
    FixBot'a Sor
    Yorum Ekle
  7. HTC Evo 4G Front Panel Replacement: adım 7, 1 resimden 1.
    • Gently insert an iPod opening tool between the rear inner frame and its plastic surround near the Micro HDMI port.
    • Carefully pry the top edge of the rear inner frame away from the front surround of the Evo.
    FixBot'a Sor
    Yorum Ekle
  8. HTC Evo 4G Front Panel Replacement: adım 8, 2 resimden 1. HTC Evo 4G Front Panel Replacement: adım 8, 2 resimden 2.
    • Insert the iPod opening tool between the rear inner frame and its plastic surround and pry up at several points along the left edge of the Evo.
    FixBot'a Sor
    Yorum Ekle
  9. HTC Evo 4G Front Panel Replacement: adım 9, 3 resimden 1. HTC Evo 4G Front Panel Replacement: adım 9, 3 resimden 2. HTC Evo 4G Front Panel Replacement: adım 9, 3 resimden 3.
    • Continue the prying procedure, now focusing on detaching the plastic surround from the bottom of the Evo.
    • Pry up the rear inner frame along the right edge using the method described in previous steps.
    • Eventually work around the entire perimeter of the rear inner frame until it is lifted slightly from the inner case.
    FixBot'a Sor
    Yorum Ekle
  10. HTC Evo 4G Front Panel Replacement: adım 10, 1 resimden 1.
    • Remove the rear inner frame from the rest of the Evo.
    FixBot'a Sor
    Yorum Ekle
  11. HTC Evo 4G Front Panel Replacement, Motherboard: adım 11, 1 resimden 1.
    • Remove the single Phillips screw securing the motherboard to the inner case near the headphone jack.
    FixBot'a Sor
    Yorum Ekle
  12. HTC Evo 4G Front Panel Replacement: adım 12, 1 resimden 1.
    • Use the flat end of a spudger to pry the motherboard off the posts securing it to the metal display tray.
    • Do not try to completely remove the motherboard just yet. It is still attached by three ribbon cables.
    FixBot'a Sor
    Yorum Ekle
  13. HTC Evo 4G Front Panel Replacement: adım 13, 1 resimden 1.
    • Carefully peel the device information sticker off the left edge of the motherboard and EMI shield to reveal three connectors covered with tape.
    • It is not necessary to peel the entire device information sticker off the EMI shield.
    FixBot'a Sor
    Yorum Ekle
  14. HTC Evo 4G Front Panel Replacement: adım 14, 1 resimden 1.
    • Fold the device information sticker up against the top of the motherboard to keep it out of the way while you work.
    • Remove the pieces of tape covering the following ribbon cables:
    • Front-facing camera
    • Front panel ribbon cable
    • Display ribbon cable
    FixBot'a Sor
    Yorum Ekle
  15. HTC Evo 4G Front Panel Replacement: adım 15, 2 resimden 1. HTC Evo 4G Front Panel Replacement: adım 15, 2 resimden 2.
    • Using the tip of an iPod opening tool, flip up the front-facing camera ribbon cable retaining flap.
    • Be very careful and gentle with these flaps. They are very easy to break or dislodge and equally difficult to reinstall.
    • Use a pair of tweezers to pull the front-facing camera ribbon cable straight out of its socket.
    FixBot'a Sor
    Yorum Ekle
  16. HTC Evo 4G Front Panel Replacement: adım 16, 2 resimden 1. HTC Evo 4G Front Panel Replacement: adım 16, 2 resimden 2.
    • Using the tip of an iPod opening tool, flip up the front panel ribbon cable retaining flap.
    • Use a pair of tweezers to pull the front panel ribbon cable straight out of its socket.
    FixBot'a Sor
    Yorum Ekle
  17. HTC Evo 4G Front Panel Replacement: adım 17, 2 resimden 1. HTC Evo 4G Front Panel Replacement: adım 17, 2 resimden 2.
    • Using the tip of an iPod opening tool, flip up the display ribbon cable retaining flap.
    • Grasp the display ribbon cable with a pair of tweezers and pull it straight out of its socket.
    FixBot'a Sor
    Yorum Ekle
  18. HTC Evo 4G Front Panel Replacement: adım 18, 1 resimden 1.
    • Carefully lift the motherboard out of the inner case, minding any cables that may get caught.
    • Be mindful of the top power button and side rocker switch, which may fall out of the front case when the board is removed.
    FixBot'a Sor
    Yorum Ekle
  19. HTC Evo 4G Front Panel Replacement, Front Facing Camera: adım 19, 1 resimden 1.
    • Gently lift the front-facing camera out of its recess in the inner case and remove it from the Evo.
    FixBot'a Sor
    Yorum Ekle
  20. HTC Evo 4G Front Panel Replacement, Front Panel: adım 20, 1 resimden 1.
    • In the following steps, you will use a heat gun to soften the adhesive securing the outer black border around the underside of the front glass panel to the inner case.
    • With the heat gun set to low, start by heating the outer black border near the upper left corner of the glass panel.
    • Try not to excessively heat the outer plastic edge of the Evo.
    • Due to the heat applied, it is normal for a layer of condensation to develop on the inside of the glass panel and/or the outside of the LCD. It can be removed with glass cleaner once the glass is separated from the display.
    FixBot'a Sor
    Yorum Ekle
  21. HTC Evo 4G Front Panel Replacement: adım 21, 1 resimden 1.
    • Gently insert an iPod opening tool between the glass front panel and its plastic surround near the upper top left corner of the Evo.
    • Carefully pry up the glass, being careful not to bend it excessively.
    • The key is to work slowly and gently to avoid breaking internal components.
    FixBot'a Sor
    Yorum Ekle
  22. HTC Evo 4G Front Panel Replacement: adım 22, 1 resimden 1.
    • Use a heat gun to soften the adhesive along the left side of the front glass panel.
    FixBot'a Sor
    Yorum Ekle
  23. HTC Evo 4G Front Panel Replacement: adım 23, 2 resimden 1. HTC Evo 4G Front Panel Replacement: adım 23, 2 resimden 2.
    • Insert the iPod opening tool between the front panel and its plastic surround and pry up at several points along the left edge of the Evo.
    FixBot'a Sor
    Yorum Ekle
  24. HTC Evo 4G Front Panel Replacement: adım 24, 2 resimden 1. HTC Evo 4G Front Panel Replacement: adım 24, 2 resimden 2.
    • Continue the heating and prying procedure, now focusing on detaching the bottom of the front panel from the plastic surround.
    • Pry along the bottom edge of the Evo to further separate the front panel from the rest of the device.
    FixBot'a Sor
    Yorum Ekle
  25. HTC Evo 4G Front Panel Replacement: adım 25, 1 resimden 1.
    • Use a heat gun to soften the adhesive along the right side of the front glass panel.
    FixBot'a Sor
    Yorum Ekle
  26. HTC Evo 4G Front Panel Replacement: adım 26, 3 resimden 1. HTC Evo 4G Front Panel Replacement: adım 26, 3 resimden 2. HTC Evo 4G Front Panel Replacement: adım 26, 3 resimden 3.
    • Pry up the front panel along the right edge using the method described in previous steps.
    • Eventually work around the entire perimeter of the front panel until it is lifted slightly from the inner case.
    • Don't try to completely remove the front panel just yet. Its ribbon cable is still attached to the inner case.
    FixBot'a Sor
    Yorum Ekle
  27. HTC Evo 4G Front Panel Replacement: adım 27, 1 resimden 1.
    • Peel the front panel ribbon cable off the adhesive securing it to the metal underside of the inner case.
    FixBot'a Sor
    Yorum Ekle
  28. HTC Evo 4G Front Panel Replacement: adım 28, 2 resimden 1. HTC Evo 4G Front Panel Replacement: adım 28, 2 resimden 2.
    • Lift the front panel out of the inner case, minding the cable still routed through the bottom of the Evo.
    • Carefully de-route the front panel ribbon cable through the slot in the inner case.
    • Remove the front panel.
    • Notice the four (4) clear plastic hooks that are adhered behind the menu buttons. Look closely. Each one is shaped differently and in a particular orientation.
    • If the replacement front panel does not have these installed already, carefully remove and transfer them from the old panel to the replacement.
    FixBot'a Sor
    Yorum Ekle
Sonuç
65 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 42
Her zaman: 122,974
