Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Gently insert an iPod opening tool between the rear panel and the inner rear frame near the headphone jack.
Use your iPod opening tool to pry up the rear case around the perimeter of the Evo.
Using the tip of your finger, lift the battery from the end closest to the camera.
Remove the battery from the rear inner frame.
Use the flat end of a spudger to pry up the red MicroSD retainer attached to the inner frame.
Use a pair of tweezers to carefully pull the MicroSD card out of its slot in the inner rear frame.
Remove six T5 Torx screws securing the rear inner frame to the inner case.
Gently insert an iPod opening tool between the rear inner frame and its plastic surround near the Micro HDMI port.
Carefully pry the top edge of the rear inner frame away from the front surround of the Evo.
Insert the iPod opening tool between the rear inner frame and its plastic surround and pry up at several points along the left edge of the Evo.
Continue the prying procedure, now focusing on detaching the plastic surround from the bottom of the Evo.
Pry up the rear inner frame along the right edge using the method described in previous steps.
Eventually work around the entire perimeter of the rear inner frame until it is lifted slightly from the inner case.
9 farklı kişi bu kılavuzu tamamladı.
Bir Yorum
You may want people to also know they have to remove the lcd panel and the rear speaker to install them in their new rear inner panel.
