Ana içeriğe geç
HTC Evo 4G Rear Speaker Replacement
Neye ihtiyacın var
  1. HTC Evo 4G Rear Speaker Replacement, Rear Panel: adım 1, 1 resimden 1.
    • Gently insert an iPod opening tool between the rear panel and the inner rear frame near the headphone jack.
    • Use your iPod opening tool to pry up the rear case around the perimeter of the Evo.
  2. HTC Evo 4G Rear Speaker Replacement: adım 2, 1 resimden 1.
    • Lift the rear panel off of the inner rear frame.
  3. HTC Evo 4G Rear Speaker Replacement, Battery: adım 3, 2 resimden 1. HTC Evo 4G Rear Speaker Replacement, Battery: adım 3, 2 resimden 2.
    • Using the tip of your finger, lift the battery from the end closest to the camera.
    • Remove the battery from the rear inner frame.
  4. HTC Evo 4G Rear Speaker Replacement, MicroSD card: adım 4, 1 resimden 1.
    • Use the flat end of a spudger to pry up the red MicroSD retainer attached to the inner frame.
    • The retainer will move about 1 mm and stop. Do not attempt to completely remove the MicroSD card retainer.
  5. HTC Evo 4G Rear Speaker Replacement: adım 5, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Use a pair of tweezers to carefully pull the MicroSD card out of its slot in the inner rear frame.
  6. HTC Evo 4G Rear Speaker Replacement, Rear Inner Frame: adım 6, 1 resimden 1.
    • Remove six T5 Torx screws securing the rear inner frame to the inner case.
  7. HTC Evo 4G Rear Speaker Replacement: adım 7, 1 resimden 1.
    • Gently insert an iPod opening tool between the rear inner frame and its plastic surround near the Micro HDMI port.
    • Carefully pry the top edge of the rear inner frame away from the front surround of the Evo.
  8. HTC Evo 4G Rear Speaker Replacement: adım 8, 2 resimden 1. HTC Evo 4G Rear Speaker Replacement: adım 8, 2 resimden 2.
    • Insert the iPod opening tool between the rear inner frame and its plastic surround and pry up at several points along the left edge of the Evo.
  9. HTC Evo 4G Rear Speaker Replacement: adım 9, 3 resimden 1. HTC Evo 4G Rear Speaker Replacement: adım 9, 3 resimden 2. HTC Evo 4G Rear Speaker Replacement: adım 9, 3 resimden 3.
    • Continue the prying procedure, now focusing on detaching the plastic surround from the bottom of the Evo.
    • Pry up the rear inner frame along the right edge using the method described in previous steps.
    • Eventually work around the entire perimeter of the rear inner frame until it is lifted slightly from the inner case.
  10. HTC Evo 4G Rear Speaker Replacement: adım 10, 1 resimden 1.
    • Remove the rear inner frame from the rest of the Evo.
  11. HTC Evo 4G Rear Speaker Replacement, Rear Speaker: adım 11, 1 resimden 1.
    • Use an iPod opening tool to pry the rear speaker out of its housing in the rear inner frame.
Sonuç
25 farklı kişi bu kılavuzu tamamladı.
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 20
Her zaman: 69,055
