Ana içeriğe geç
HTC Flyer Back Cover Replacement
Neye ihtiyacın var
  1. HTC Flyer Back Cover Replacement, Back Cover: adım 1, 3 resimden 1. HTC Flyer Back Cover Replacement, Back Cover: adım 1, 3 resimden 2. HTC Flyer Back Cover Replacement, Back Cover: adım 1, 3 resimden 3.
    • Apply pressure along the bottom of the white panel containing the camera and push upwards.
    • It may take some effort, but it will smoothly slide off.
    FixBot'a Sor
    Yorum Ekle
  2. HTC Flyer Back Cover Replacement: adım 2, 3 resimden 1. HTC Flyer Back Cover Replacement: adım 2, 3 resimden 2. HTC Flyer Back Cover Replacement: adım 2, 3 resimden 3.
    • Unscrew the four of 3.5mm Torx T5 screws that run along the sides of the exposed innards.
    • All screws in the device will use the Torx T5 screwdriver, so keep it handy.
    FixBot'a Sor
    Yorum Ekle
  3. HTC Flyer Back Cover Replacement: adım 3, 3 resimden 1. HTC Flyer Back Cover Replacement: adım 3, 3 resimden 2. HTC Flyer Back Cover Replacement: adım 3, 3 resimden 3.
    • Remove the black protective piece of plastic by sliding it upwards.
    • Remove the two 3.5mm Torx #5 screws holding the protective plastic down on along the sides.
    • A center 3.5mm Torx screw will be covered by "VOID" sticker.
    • Either remove the sticker or jam the screwdriver into the screw, and remove the screw.
    • Remove the protective panel by sliding it upwards.
    FixBot'a Sor
    Yorum Ekle
  4. HTC Flyer Back Cover Replacement: adım 4, 2 resimden 1. HTC Flyer Back Cover Replacement: adım 4, 2 resimden 2.
    • Before removing the back cover, apply some scotch tape to the volume buttons to prevent them from falling out of the back panel.
    • Use a plastic opening tool to lever up the top half of the cover.
    • Lift the back panel up and remove it from the device.
    FixBot'a Sor
    Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Justin Funk
485 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 8-5, Leahy Fall 2014 USF Tampa, Team 8-5, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S8G5
3 Üyeler
12 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 20
Her zaman: 743
