Ana içeriğe geç
HTC Flyer Camera Replacement
Neye ihtiyacın var
  1. HTC Flyer Camera Replacement, Back Cover: adım 1, 3 resimden 1. HTC Flyer Camera Replacement, Back Cover: adım 1, 3 resimden 2. HTC Flyer Camera Replacement, Back Cover: adım 1, 3 resimden 3.
    • Apply pressure along the bottom of the white panel containing the camera and push upwards.
    • It may take some effort, but it will smoothly slide off.
  2. HTC Flyer Camera Replacement: adım 2, 3 resimden 1. HTC Flyer Camera Replacement: adım 2, 3 resimden 2. HTC Flyer Camera Replacement: adım 2, 3 resimden 3.
    • Unscrew the four of 3.5mm Torx T5 screws that run along the sides of the exposed innards.
    • All screws in the device will use the Torx T5 screwdriver, so keep it handy.
  3. HTC Flyer Camera Replacement: adım 3, 3 resimden 1. HTC Flyer Camera Replacement: adım 3, 3 resimden 2. HTC Flyer Camera Replacement: adım 3, 3 resimden 3.
    • Remove the black protective piece of plastic by sliding it upwards.
    • Remove the two 3.5mm Torx #5 screws holding the protective plastic down on along the sides.
    • A center 3.5mm Torx screw will be covered by "VOID" sticker.
    • Either remove the sticker or jam the screwdriver into the screw, and remove the screw.
    • Remove the protective panel by sliding it upwards.
  4. HTC Flyer Camera Replacement: adım 4, 2 resimden 1. HTC Flyer Camera Replacement: adım 4, 2 resimden 2.
    • Before removing the back cover, apply some scotch tape to the volume buttons to prevent them from falling out of the back panel.
    • Use a plastic opening tool to lever up the top half of the cover.
    • Lift the back panel up and remove it from the device.
  5. HTC Flyer Camera Replacement, Battery: adım 5, 2 resimden 1. HTC Flyer Camera Replacement, Battery: adım 5, 2 resimden 2.
    • Gently unfold the black tape along the top that covers the cable attachment points.
    • Leave the tape partially attached so that it can be easily re-attached.
  6. HTC Flyer Camera Replacement: adım 6, 3 resimden 1. HTC Flyer Camera Replacement: adım 6, 3 resimden 2. HTC Flyer Camera Replacement: adım 6, 3 resimden 3.
    • Use the tip of a spudger as a lever to disconnect the four cable connectors.
    • Gently pull out these cables after releasing the back piece.
  7. HTC Flyer Camera Replacement: adım 7, 1 resimden 1.
    • Remove the single 2.5mm Torx T5 screw holding the battery down along the top side.
  8. HTC Flyer Camera Replacement: adım 8, 3 resimden 1. HTC Flyer Camera Replacement: adım 8, 3 resimden 2. HTC Flyer Camera Replacement: adım 8, 3 resimden 3.
    • Wedge the flat end of a spudger inbetween the battery and the front panel assembly.
    • Run the flat end of a spudger along the top edge of the battery to separate it from the adhesive securing it to the front panel assembly.
    • If you encounter any resistance from the remaining adhesive, simply use the flat end of a spudger to remove the excess adhesive.
  9. HTC Flyer Camera Replacement, Motherboard: adım 9, 2 resimden 1. HTC Flyer Camera Replacement, Motherboard: adım 9, 2 resimden 2.
    • Remove the four 2.5mm Torx #5 screws that run along the motherboard's rim.
  10. HTC Flyer Camera Replacement: adım 10, 1 resimden 1.
    • Use a spudger to remove the two black ground wires from the right side of the motherboard.
    • Remove the two multicolored speaker cables on the right side by lifting up the "lever" on the opposite side of the cable socket and then pulling out the cables.
  11. HTC Flyer Camera Replacement: adım 11, 2 resimden 1. HTC Flyer Camera Replacement: adım 11, 2 resimden 2.
    • Lift up the translucent yellow tape to expose the cable sockets.
    • Use the spudger to lift up the cable's "lever".
    • Pull out the cables.
  12. HTC Flyer Camera Replacement: adım 12, 2 resimden 1. HTC Flyer Camera Replacement: adım 12, 2 resimden 2.
    • Remove the cable along the headphone in the same way the lower cables were removed.
  13. HTC Flyer Camera Replacement: adım 13, 1 resimden 1.
    • Grip the motherboard by its edges and pull it out.
  14. HTC Flyer Camera Replacement, Headphone Jack: adım 14, 2 resimden 1. HTC Flyer Camera Replacement, Headphone Jack: adım 14, 2 resimden 2.
    • Remove the single 2.5mm Torx T5 screw.
  15. HTC Flyer Camera Replacement, Camera: adım 15, 1 resimden 1.
    • Remove the camera flex cable.
Sonuç
Joshua Mahon
445 İtibar
3 adet Kılavuz yazıldı
Ekip
IUPUI, Team S5-G5, Wilson Fall 2018 IUPUI, Team S5-G5, Wilson Fall 2018 üyesi
IUPUI-WILSON-F18S5G5
4 Üyeler
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 11
Her zaman: 231
